CV axle thicker boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MagnumTaco, Dec 26, 2014.
  1. Dec 26, 2014 at 11:03 AM
    MagnumTaco
    MagnumTaco [OP] Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    I am having to replace a CV axle due to to much lift. My boot tore/warn out in about 25,000 miles. I am running just over 3 inches of lift. I am looking for an after market CV axle that has a thicker boot so it will last longer then OEM, anyone know of one? I am also considering lowering the front a half inch and dealing with a little bit of a rake.
    Thanks
  2. Dec 26, 2014 at 11:06 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    SDHQ makes a high angle boot kit and do the boot slide mod when you swap boots....Stick with OEM CV's, aftermarket's are crap!
  3. Dec 26, 2014 at 11:13 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    You need a long travel or high angle boot. Here is one type. You can goggle for others. You may even have to install heavy duty CV axels to get certain boots.
  4. Dec 26, 2014 at 11:37 AM
    MagnumTaco
    Tony
    New Mexico
    Those boots are awesome. Toyota CV axles are super expensive. I might have to buy a cheap one to get by for now and replace with Toyota and these boots a little later.
  5. Dec 30, 2014 at 12:17 PM
    MagnumTaco
    Tony
    New Mexico
    So what is the boot slide mod?
  6. Dec 30, 2014 at 12:20 PM
    GoldyLocks
    GoldyLocks Well-Known Member
    Mesa az
    97 caged 4x4 tacoma, SR1 Rhino
    LOL
    you get a new clamp for the small side of the boot, slide the boot up the shaft a bit, and reclamp.
    makes it so the fins are further away and dont rub.
    if you search it will come up.
  7. Dec 30, 2014 at 12:28 PM
    MagnumTaco
    Tony
    New Mexico
    Nice I found it thanks, Goldy.
  8. Dec 30, 2014 at 12:29 PM
    GoldyLocks
    Mesa az
    LOL
    welcome!
