CV axle threads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Impulse05Taco, Jun 29, 2012.
  1. Jun 29, 2012 at 2:06 PM
    Impulse05Taco
    Impulse05Taco [OP] Well-Known Member
    Colorado
    05 Tacoma V6 TRD Offroad
    I am getting ready to replace a wheel bearing but the threads are damaged keeping me from removing the spindle nut. Yay for buying used...anyhow does anyone here have any tips on how to proceed. It appears who ever did the last bearing change used a metal hammer and hit the threads pinching three threads into a lump near the end of the cv axle. Thanks in advance.
  2. Jun 29, 2012 at 2:07 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    a very small file, and file them to a point where they are usable, or purchase a proper thread chaser
  3. Jun 29, 2012 at 2:16 PM
    Impulse05Taco
    Colorado
    No pics yet had to stop and put her back together for the work week. I dont think a file will do much because the end of the axle is not round anymore. The area impacted sticks out a bit. I'm almost thinking I need to either grind it down or try and cut it off since the spindle nut will come about 3/4 of the way to the end of the threads but I dont know that a sawsall with a demo/steel blade can handle that.
  4. Jun 29, 2012 at 2:19 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    subbed to see the outcome
    good luck OP
  5. Jun 29, 2012 at 2:20 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Get an angle grinder and cut off the nut.
  6. Jun 29, 2012 at 3:26 PM
    Impulse05Taco
    Colorado
    Luckily the axle half is only 60 bucks so worst case I'll take scuba's advice and cut the nut and replace the axle. I'll snap some pics and post when the horror is over. thanks for the suggestions all.
  7. Jun 29, 2012 at 3:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah I'd just either grind down the offensive area, or cut the entire end of the shaft off.
  8. Jul 2, 2012 at 12:17 PM
    Impulse05Taco
    Colorado
    It's a hard to snap a good shot that shows the three threads pinched but from this angle you can see the spot impacted. Today I ground about two or three sixteenths of an inch off the end (picture was taken before grinding) but had to do so quickly at work and put it all back together. (no electricity to the carport at my apartment complex) So now shes ready for another attempt to get the nut off. If it weren't for my job this would be done lol. I'll post with my next success/defeat.
  9. Jul 2, 2012 at 1:09 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    go buy a metric thread file... they do wonders for shit like that
  10. Jul 2, 2012 at 4:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. It doesn't look too bad from the picture. A little elbow grease should get that cleaned up... and you won't have to buy an axle.
  11. Jul 19, 2012 at 4:05 PM
    Impulse05Taco
    Colorado
    Well after grinding off all the mashed threads I used a file to fix the last thread at the end and problem solved. After all that changing the bearing was a breeze.
