CV Axle Wont Stay In
Discussion in '1st Gen. Tacomas (1995-2004)' started by fowheeldrive, Mar 29, 2025.
  1. Mar 29, 2025 at 1:31 PM
    fowheeldrive
    fowheeldrive [OP] New Member
    Enrique
    1999 Tacoma Ext. Cab 4wd V6 5Spd
    3in Lift 33in Tires 1in Front diff drop URD Short throw shifter
    I have a 1999 Tacoma 4wd V6 with manual locking hubs and a manual transmission. I snapped my driver side axle in the differential. Luckily I was able to get it all out but now I am having issues getting the new axle to stay inside the differential. When I put the new axle it it popped in normally, fully seated. When I went to test drive it the axle came out the differential immediately . Not completely, but enough to make some HARSH grinding noises. I have read stuff about the ecgs bearing but is there anything else it can be? thank you.
  2. Mar 29, 2025 at 1:34 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    If you snapped your CV inside the spider of the diff then your needle bearing is absolutely F’d. Check the spider gear and make sure the 29 splines look clean and STRAIGHT. I would either replace the diff or go with a bushing from ECGS. That part is a must if you plan to keep.
    any pics of the debris? Was the break within the male spline region of inboard side of the CV?
  3. Mar 30, 2025 at 7:11 PM
    fowheeldrive
    Enrique
    i sold it lol, thank you though
  4. Mar 31, 2025 at 1:05 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    you sold the truck not to deal with this issue?
  5. Mar 31, 2025 at 1:14 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Note to self... don't buy used... At least not from this guy, lol.
