CV Axles w/leveling kit (Ripped boots)
Discussion in 'Suspension' started by SubFrozen, Nov 1, 2010.
  1. Nov 1, 2010 at 11:19 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Hey guys--
    The boots tore on my CV Axles due to a 3" leveling lift on the front and the angle being too steep. I was told I could adjust the boots on the new CV Axles I picked up, moving them down a little bit.
    Has anyone tackled and solved this issue so the boots don't rip? I'm not sure if I want the hassle or doing it, or if I just replace the CV Axles each year, or, this one time and then pick up an actual lift.
  2. Nov 1, 2010 at 11:51 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    what lift do you have? you can install a diff drop but there are downsides to it just like everything else.
  3. Nov 1, 2010 at 11:52 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    What kind of lift do you have?
  4. Nov 1, 2010 at 12:12 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" leveling lift
  5. Nov 1, 2010 at 12:20 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have been running at 2.5 for almost a year with no cv problems....no wear at all
    mabye try lowering it a lil
  6. Nov 1, 2010 at 12:44 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    I.E., buying a new leveling lift, or just buying a new lift all together?
  7. Nov 1, 2010 at 2:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Check this out: This kit will improve the CV Axle angles. Depending on how much angle you have, the diff drop kit may be enough to keep the fins on your boots from being in contact.
  8. Nov 1, 2010 at 2:28 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    I hear the diff drop could allow debris (rocks, hills, small animals) to whack it and cause underbody damage. Should I even try it, or just deal with boots now and then?
  9. Nov 1, 2010 at 2:29 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    What about these, Ive never heard anything about them [​IMG]
  10. Nov 1, 2010 at 2:35 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    A boot, over a boot? Might do the trick.
  11. Nov 1, 2010 at 2:42 PM
    ktmrider
    Junk
    I dont really understand how they work, but maybe
