CV Boot gone bad, need some advice/help
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Jan 7, 2012.
  1. Jan 7, 2012 at 4:11 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  2. Jan 7, 2012 at 4:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I drove on mine with a completely torn boot for 3 months with no problem. And that was in heavy snow/salt conditions.
    OEM is obviously the best, but super expensive. I would recommend just changing the whole axle with one from autozone or oreileys with the lifetime warranty. Changing the whole axle is easy, takes 30 minutes if you know what you're doing.
    http://www.4x4wire.com/toyota/maintenance/cv_axle/
  3. Jan 7, 2012 at 4:19 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    You can probably drive for quite a long while with it like that. Went to install my lift when I noticed a torn boot. No idea how long it had been like that.
    I carry a GSP axle as a spare. You can pick em up at Advance Auto, Auto Zone, etc. We just replaced pyroskier's CVs with GSP axles. They seem pretty good... but I kinda wonder if it's hit/miss with them. Out of the three GSP axles... 1 was missing the spare axle nut that usually comes with, 1 was missing the dust cover (that contacts the spindle), and one appeared to be unpainted/finished.
    It's not difficult for one person to do... helps to have done it before and know what the hell you're doing though.:D
  4. Jan 7, 2012 at 4:20 PM
    Mi Vida Taco
    Mi Vida Taco Well-Known Member
    Texas
    2010 taco
    http://www.tacomaworld.com/forum/technical-chat/21192-how-change-cv-axle-01-04-add-tacoma.html
    this is for the '01-'04 tacoma, should help ya, i literally just got inside from completing an axle swap on my 2010 from a torn cv boot myself, it was a pretty frustrating job but can easily be done by yourself. what took me the longest was the confusion from others saying the hub has to be pressed, but only if it was seperated. mine never was, so coulda been done a lot sooner. but good luck, lemme know if you have any more questions. oh got my axle from auto zone on the cheap and it looked to be pretty decent quality. drove it and it drove just like it did before.
  5. Jan 7, 2012 at 4:23 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    mine had no dust covers or nut. I had to swap the seals over to the new one and re use the nut.
    I got my axle refurbished at autozone for $60.
  6. Jan 7, 2012 at 4:42 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Awesome, thanks for the help guys! Ive been researching (I posted first which I usually dont do but this had me kind of upset) and I think Im going for the replacement CV axle.
    New question. Seems to be lots off confusion as to how big the axel nut is:
    Says 35mm here: http://www.4x4wire.com/toyota/maintenance/cv_axle/
    Says 36mm here: http://www.customtacos.com/tech/index.php?article=113
    Says 36mm here: http://www.tacomaworld.com/forum/technical-chat/21192-how-change-cv-axle-01-04-add-tacoma.html
    mjp2 says 35mm here: http://www.tacomaworld.com/forum/2nd-gen-tacomas/45268-replacement-cv-boots.html
    Chris4x4 says 34mm and is corrected by tacomaman06 to 36mm here: http://www.tacomaworld.com/forum/technical-chat/42970-trouble-removing-front-axles-2nd-gen.html
    So before I order a socket at Sears.com, what size is the bolt?
  7. Jan 7, 2012 at 4:47 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    36"
    Some of those links are 2nd gen write ups
  8. Jan 7, 2012 at 4:50 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ahhh, that makes sense now, thanks.
  9. Jan 7, 2012 at 4:52 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    The OEM axles are a good bit stronger than aftermarket from what I've heard. If it's torn and still working, why not just get it rebooted? You'd be out less money and have an OEM axle.
  10. Jan 7, 2012 at 5:09 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Can I fit Tundra CV axles on here? A neighbor was parting out his tundra (totaled) and I thing he still has his axles. Ive seen them on an LT truck but can they be added to a stock truck?
  11. Jan 7, 2012 at 5:10 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Are you sure the boot is ripped?
    To me it just looks like there is grease coming from the seal around the shaft. New clamp will fix that.
    I have two GSP axles in my truck and they are fine for over a year of wheeling. And lifetime warranty from advanced auto.
  12. Jan 7, 2012 at 5:13 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    ^X2
    Looks like the boot clip has snapped, mine did the same thing. I just put a hose clamp on it and no problems since.
  13. Jan 7, 2012 at 5:21 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ill look again tomorrow. Two kids in the house now so not much truck time. I hope that's the issue because this is going to be my daily driver once again come Monday.
  14. Jan 7, 2012 at 7:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    My axle nut was a 35mm
  15. Jan 8, 2012 at 1:49 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    NOOOOOOOOOOOOO
    You can not swap in the longer CVs without going full LT. But if he is handing them out..go get them! You might want em later :p or could sell em at least. But you can not run these without the longer lower control arm...which means you need a longer UCA...which means you need longer coilovers...haha
    Can't believe everyone ignored this lol
  16. Jan 8, 2012 at 2:56 AM
    KAWAIANIANI
    KAWAIANIANI Well-Known Member
    TRD BLACKED OUT
    Weather tech stone deflector, Craven speed stubby antennae,DTLT and rear O2 Sims, URD Y pipe, 40 series flowmaster w/ 3" piping. Urd maf calibrator, TRD supercharger, TRD CAI.
    #1. Ask yourself this question: When does something fail?
    #2 Check if it just needs a clamp, Possibly see if the cv boots Allpro offers will do the trick.
    #3 If its just a boot its simple, If you do it right you can rent the socket from a parts store if you dont already have the socket so you dont have to buy it and also all you would have to do is put a deposit down and you get it back when the tool is returned.
  17. Jan 8, 2012 at 3:03 AM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    are OEM cv's really expensive :eek: oh boy guess i better go get the ones they were selling for 20 dollars each "o
  18. Jan 8, 2012 at 3:13 AM
    KAWAIANIANI
    TRD BLACKED OUT
    If this is in regards to my post, the only reason I say AllPRO is they are for the LT setup so they were designed to handle more abuse which means less maintenance for the owner.
  19. Jan 8, 2012 at 10:43 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I can use the outer joint from the Tundra and put it on the Tacoma axle though right? While reading up on the CV axle change, I read that the Tacoma's CV axle are not true constant velocity axles like the Tundra.
    I think its just a clamp that needs to be replaced which is very good news, but sometime in the future, I would like to replace the CV axles.
    Thanks all for the help!
  20. Jan 8, 2012 at 11:09 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Sooo much easier to just use a stock replacement axle than to mess around with the tundra one.
    Also I agree it looks like you just need a clamp. but my axle started that way, then quickly tore because of dry rot and my 2" lift.
