CV Boot or CV Shaft Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaneC, Mar 13, 2021.
  1. Mar 13, 2021 at 10:53 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    2008 Toyota Taccoma Off Road
    I have an 08 4.0 taco 4x4 and I have been catching up on much needed maitenance now that money isn't so tight. The boots are torn on both sides and look pretty rough. I was looking over a bunch of the CV related posts and I am not really sure if i just need to replace the bootsn and seals, or if I should replace the whole shaft. Any thoughts would be appreciated.
    I am not sure if this is related to the CV shaft or not, but I am noticing a knock going around corners that is coming from the front driverside wheel. I can't pinpoint exactly where it comes from but I figured it might be related to the CV shaft since it's the only thing that stands out to my eye.
  2. Mar 14, 2021 at 5:04 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Fwiw, I have a knock that appears on turns every once in a while. I can't pinpoint it and I though it might've been the cv as well. I had already replaced everything else I could think of (body mount bushings, LCAs, etc). It's still there.
    Anyway, I guess it depends on your patience. If you want to pull the shaft and reboot it, that's obviously a cheaper alternative. Personally, I opted to just swap in a new cv for sake of time. Same with all other components I've replaced. Then if you find yourself going through axles often, keep one as a spare that is already rebuilt and ready to go.
  3. Mar 14, 2021 at 5:14 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I installed a new cv axle instead of rebuilding mine, new ones aren't expensive so its not worth my time rebuilding them.
  4. Mar 14, 2021 at 5:47 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    I had the boots go out on mine in colorado and had both replaced out there so I could keep wheeling. This summer Ill do a once over and see if I can just replace the boot and be done or if it needs to be rebuilt. If i can save them with a boot ill do that and have a pair of OEM spares. If not Ill sell them to someone or something and pick up some new ones for spares.
  5. Mar 14, 2021 at 8:09 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If it were me, I'd likely replace them and keep the originals for spares pending a future rebuild. Then, four years from now, I'd get tired of moving them around my shop and give them to someone that needs them.......
    Marc70 likes this.
  6. Mar 14, 2021 at 4:30 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    I was thinking the same, rock auto has them at $45 a piece. That seems well worth the time and effort saved. I guess it's just a matter of preference then? Hopefully this removed the knock.
  7. Mar 14, 2021 at 4:36 PM
    Bishop84
    Bishop84 Well-Known Member
    I would run remanufactured axles for sure. Make sure the seals on the front diff aren't leaking because now is the time to change them.
    TnShooter likes this.
  8. Mar 14, 2021 at 7:35 PM
    TacoTuesday1
    FL
    people are supposed to replace boots every 100k but most do not
    they are like $20
    it is easiest to start with a boot kit
    shafts do not wear out. they break if you jump a rock.
    CV joints develop play and click when their boot is left torn for a long time, necessitating joint replacement that costs more than a boot replacement.
    other components may be worn such as ball joints. It is not a bad idea to start with what is known to be bad. Such as a loose CV joint.
    Anything on a front suspension tends to start going bad at 100k.
    I am curious to know what upgrades there are. Certain companies sell bigger boot kits to handle higher angles associated with lifted suspension, which 99% of Tacoma's have.
    It seems pointless to install a stock boot design onto something with 2, 2.5, 3" or greater lift.
    OEM is usually better quality than aftermarket, with stronger metal that is more precisely ground.
  9. Mar 14, 2021 at 8:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have nothing to add other than, you might as well do the ECGS Bushing while you are at it.
    You are 90% there with the axle removed.
    whatstcp likes this.
  10. Mar 15, 2021 at 12:40 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Crow Horse likes this.
  11. Mar 15, 2021 at 4:36 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I never thought of replacing my CV boots as part of regular maintenance...I don't recall seeing a service interval anywhere for them either. Is the 100k quoted above the general concensus and that the boots should be replaced as part of regular maintenance?
  12. Mar 15, 2021 at 10:10 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Anyone run the cheap ones from rockauto or generic parts stores?
    i dont feel like paying 390 for oem..
  13. Mar 15, 2021 at 12:24 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    CVJ Axles best stockers are about $200 ea. Much better than the Chinese axles at the auto stores. Based on my reading, some have had luck with the discount axles and others haven't. Spending a little more for peace of mind is worth it in the long run......
  14. Mar 15, 2021 at 12:57 PM
    coopcooper
    alberta canada
    200 usd plus core plus shipping i think its cheaper to go with oems at that point:pout:
  15. Mar 15, 2021 at 1:30 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    But you get your core charge back. It's only about $30 for the return shipping.
  16. Mar 15, 2021 at 8:18 PM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    My shafts were fine and I replaced the boots with the tutorials on this website. Took about an hour plus on first side and half hour on the second. Mine slightly lifted so did the boot spacer mod on this web site also. I think stock joints are much better. Had a little trouble with the band strap on one of the boots slipping and just ended up using a radiator band on it, no problems.
