CV boot problem
Discussion in 'Technical Chat' started by Tsenekos, Nov 18, 2009.
  1. Nov 18, 2009 at 1:43 PM
    Tsenekos
    Tsenekos [OP] Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    So I noticed the clamp that holds the cv boot on the shaft slipped off (not sure how) and some grease spit out from driving (not far) is there a way to get some grease back inside the boot without disassembling the drive axel? thanks for any help on this guys.:)
  2. Nov 18, 2009 at 1:46 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    if its not to much grease that has come out just put a pipe strap on it a roll on. Not sure about getting grease back in there.
    edit: add pic
  3. Nov 18, 2009 at 1:59 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    thats exactly what I put on seems better than the factory clamp too:D
  4. Nov 18, 2009 at 2:45 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    anybody know about getting grease in it...anybody???
  5. Dec 7, 2009 at 10:53 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    The drivers side outer band came loose on mine with only about 9000 miles. Took it to the dealer they tried to fix it and it fell off next day. The ordered a new band, it was put on and it also came loose. The ended up putting a whole new half shaft in to fix this problem because they could not get a band to stay on. Good luck to you getting this resolved.
  6. Dec 8, 2009 at 10:00 AM
    Tsenekos
    Greg
    Edmonton, CANADA
    hey thanks the hose clamp is holding great going to leave it for abit but I wish there was a way I could put alittle grease back in cause some spit out Ive heard a syringe is possible:confused:
  7. Dec 8, 2009 at 10:42 AM
    Tsenekos
    Greg
    Edmonton, CANADA
