CV Boot tore
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phuket, Apr 21, 2012.
  1. Apr 21, 2012 at 11:35 AM
    Phuket
    Phuket [OP] Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    I knew it was going to happen, just didn't prepare for it. Should I get a new Napa axle or a re manufactured axle? I saw the thread about replacing the front axle on an 01 taco, does anyone have any tips for me? Should I do the boot slide mod on the new axle? sorry for being full of questions, I just don't want to replace the axle again. I looked at toyota parts direct and want to know what I would need if I buy there.
    http://www.toyotapartsdirect.com/parts.html
  2. Apr 21, 2012 at 11:39 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    i haven't had to replace the axle on my tacoma, but i've done one on a camry and it can be a PITA. i bought one from autozone that comes with a lifetime warranty and it's been about 2yrs now and it's holding up just fine. on the camry it was a bitch on the driver side.
  3. Apr 21, 2012 at 1:47 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Did mine a couple weeks ago. Was my first time. Was easy, honestly. The longest part for me was getting the new cv all the way back in. It slides in a little bit...and then needs a good hit to get it to pop in. I ended up using a long piece of metal and pressed it against the lip of the inside of the cv, then hit it with a hammer and it popped right in. I bought a cv from autozone, brand new not re-man'd. One autozone store wanted a core charge, went to another autozone and no core...so keep that in mind (unless you don't mind giving them your old cv, kept mine to rebuild). And the autozone cv has less fins than stock so they don't even come close to touching for me, so didn't do/need the boot slide mod. Only really wheeled hard twice on it, but no problems yet. Not expecting any. Iirc Jlee runs autozone cv's? Good enough reason for me lol.
  4. Apr 21, 2012 at 9:20 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    CV axles are on IFS Toyotas are simple. Between the three Toyota trucks I own I've probably removed/installed or replaced them 20 times.
    This is probably the most straitforward and helpful writeup I've seen.
    http://www.4x4wire.com/toyota/maintenance/cv_axle/
    If you're looking to prolong the inner cv boot, I wouldn't bother with the boot slide mod. Just do it right from the beginning and replace the inner CV with a bates style 930 cv boot.
  5. Apr 21, 2012 at 9:23 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Just because the boot tore doesnt mean you need a new axle. If it just tore recently throw a new boot on. I got a new boot local here for $12, with new clamps, retaining rings and grease.
    Curtmagurt likes this.
  6. Apr 21, 2012 at 9:35 PM
    TacoBran
    TacoBran Your Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    03 Double Cab 4x4 TRD
    Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs
    Napa just relabels these and charges double the price
    http://my.cardone.com/English/club/members/customer/ecat_brands/imageinfo.asp?PARTNUM=665134
    I've read the autozone ones are junk but it seems others are proving different.
    Guess it comes down to if you wheel, how hard you wheel, and what kind of wheeling you do
    Fwiw I just tore a boot on mine, went to oreily's and bout a new boot n grease for $12.
  7. Apr 21, 2012 at 11:19 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Yeah I bought a new boot also. So I can keep the oem as a spare. So if I have any problems with the autozone cv on the trail I can pop the oem back in and go to autozone and get a free cv.
  8. Apr 22, 2012 at 1:14 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    I don't wheel very hard, so best option would be go to autozone and get their CV with a lifetime warranty? The reason i'm doing a whole axle replacement is because I searched and another thread said it's easier to just replace the half shaft.
    EDIT: I called a couple autozones around me and they all have a core charge... does that mean I have to send them my old CV axle?
  9. Apr 22, 2012 at 2:25 PM
    TacoBran
    Brandon
    Peoria, AZ
    Personally if you do any wheeling at all keep your oem and rebuild it. Get one from rockauto in the link I posted above. They don't require a core charge.
    Yes it is easier and less messy to just swap the cv. Since to replace the boot you have to pull the cv then take it apart, clean reboot grease and reinstall.
    And to answer your question ya, they want your old one.
  10. Apr 22, 2012 at 3:50 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    quick question; How much angle is too much and will eventually lead to a boot failure due to rubbing?
  11. Apr 22, 2012 at 4:10 PM
    TacoBran
    Brandon
    Peoria, AZ
    When the inner fins touch. If you can slide a piece of paper between the inner fins you are good to go.
    Manual hubs would be ideal since then the boots would only be turning/touching when your in 4x4
    Auto hubs they are always turning. When they rub they start to make little wear marks and weaken the rubber. Then one day they let go and spray grease everywhere
  12. Apr 22, 2012 at 4:12 PM
    12Tac
    12Tac Well-Known Member
    Fort Collins Colorado
    2012 TRD Spruce
    Leer 100XR, custom surveillance cameras, FN BFD wheels (Winter - Blizzaks), FN Konig Coutersteers (Spring, Summer-Toyo AT2), NFab side steps. Various counter measures.
    Oh dear
  13. Apr 22, 2012 at 8:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Tearing a CV boot is really no big deal. Fling some grease around and fix it when you can. If however you manage to do this...then you have a problem :anonymous:
  14. Apr 22, 2012 at 11:03 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i think i might be good then. I would have loved to get manual hubs...but it didnt work out that way unfortunately.
  15. Apr 22, 2012 at 11:59 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I went with an autozone reman axle instead of swapping boots. Swapping boots is a pita and I would much rather swap in an axle and be done with it. The lifetime warranty is nice too! I think if you get a new instead of a reman axle from autozone there is no core charge but I could be wrong. You should try going in and talking with someone that works there to find out.
  16. Apr 23, 2012 at 7:11 AM
    TacoBran
    Brandon
    Peoria, AZ
    You can always add em later. That's most likely what I'll do.
  17. Apr 23, 2012 at 10:01 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Boot change is easy. 2 retaining clips and it's off. Took me maybe 5 mins longer than a axle swap and only cost $12.
