cv boot tore
Discussion in 'Suspension' started by Stillfly199, Feb 19, 2010.
  1. Feb 19, 2010 at 10:58 AM
    Stillfly199
    Stillfly199 [OP] ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Well on my way back up north and I noticed that there is oil all over the passenger side from the cv. I am headin 11hrs north, is this something I need to get replaced now or can it wait? I imagine it has to now, but I am hoping it doesn't
  2. Feb 19, 2010 at 11:01 AM
    timbo805
    timbo805 Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    im thinking it could probably hold up a couple more days for shure
  3. Feb 19, 2010 at 11:01 AM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I would get it done now after because that 11 hr trip the cv axel will be shot and the repair will be alot more
  4. Feb 19, 2010 at 11:11 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I think periodically greasing it should get ya home... as long as there isnt rain/snow in the forecast to contaminate it.
  5. Feb 19, 2010 at 11:15 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I am assuming it is the cv, I can't find a hole on the boot but there is oil slung everywhere, looks like a thread I saw a while ago, what kind of grease?
  6. Feb 19, 2010 at 11:20 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    If it's just a pin hole in the boot you'll be fine for the drive. Worry about it once you're back home and can replace the boot completely.
  7. Feb 19, 2010 at 11:25 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I've crawled around under it and can't find the zerk, where is it? I want to at least hit it at the halfway mark with grease
  8. Feb 19, 2010 at 11:32 AM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    it eaither has a hole or the clamp came loose and the boot is flinging greas out of the end eaither end if their is a hole like he said get a greas gun with some synthetic grease stick it into the hole and fill it up clean the boot and apoxy or ducktape around the boot then you need to get a boot replacement kit iv seen them on ebay or ask autozone if they have one. the dealer has them in stock deppending on were you live....
  9. Feb 19, 2010 at 11:38 AM
    mjp2
    NJ
    FYI, a replacement CV half shaft assembly, ready to install, is $67 plus shipping from Rock Auto after the core return.
    http://www.rockauto.com
    Can't beat the price and they're good. I picked one up awhile back to scavenge some parts and it's a nice piece that makes replacing just the boots more of a hassle than it's worth. Replace the whole shaft and save yourself the time and rags.
  10. Feb 19, 2010 at 11:50 AM
    mjp2
    NJ
    Killer deal!
    Yeah, I no longer take a whole lot of pride in the time it takes for me to tear down the front end on the truck. Would have been more impressive if I didn't have to do it so many times. :eek:
  11. Feb 19, 2010 at 12:24 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Went to pep boys, got some cv grease and hose repair tape, it was only a tiny hole, so in order to get grease in I had to make it bigger so hopefully this holds up
  12. Feb 19, 2010 at 12:45 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Well the tape didn't hold, lost all the grease and now I have a bigger hole
  13. Feb 19, 2010 at 12:52 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Ok, so is it possible to just pull the axles off and cap them so I can make the trip home?
  14. Feb 19, 2010 at 12:58 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Sorry to hear about this. What kind of tape did you use?
  15. Feb 19, 2010 at 1:04 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I says hose repair tape, they said it wouldn't come off when grease gets on it haha, but I know blackhawke was able to cap his off, is this something I can have them do with mine?
  16. Feb 19, 2010 at 1:33 PM
    mjp2
    NJ
    Dismantling the inner CV is a piece of cake but that outer CV required a 40 tons of pressure to pop the stub shaft out of the CV cage. That was after cutting up the axle shaft itself to allow me to rotate the CV cage enough to pop out the bearings so I could remove the cage and get it in the press.
    With the larger hole in the boot it's time to accept that you're replacing the whole axle when you get home and hit the road.
  17. Feb 19, 2010 at 2:04 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    So just say fuck it and drive home?
  18. Feb 19, 2010 at 2:08 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Why don't you use some of that tape you bought to wrap it again. Then wrap duck tape over that. Might hold better.
  19. Feb 19, 2010 at 2:18 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Ya, yours is the one I saw, so just wrap it and head home and if it holds it holds? I know I'll need new axles, I have a guy that can help me at home, no big deal
  20. Feb 19, 2010 at 3:00 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Thanks everyone, I taped it and filled it once more, tryin to get through LA before 5 haha
