cv boot
Discussion in '1st Gen. Tacomas (1995-2004)' started by jblair, Jul 10, 2011.
  1. Jul 10, 2011 at 9:46 PM
    jblair
    jblair [OP] Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    Soooo question... stupid question that I'm pretty sure I know the answer to... How bad is a torn cv boot? why is it bad? and can somebody point me in the way of a cv replacement writeup for a 99 or similar truck with manual locking hubs? Because search isn't helping much and the inside boot is torn all the way around. On the plus side... I'm picking up a diff drop and some eibachs to go with the 5100's on tuesday :cool:
  2. Jul 10, 2011 at 9:50 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    it means you will have no cv axle due to friction with no lubrication, and no 4x4 within hours I'd think
  3. Jul 10, 2011 at 9:53 PM
    jblair
    Colorado
    99 taco 2.7L I4
    so the boot holds gear oil or what?
  4. Jul 10, 2011 at 10:10 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    it holds grease, i'm trying to find out what kinda of grease right now for myself.
    they are packed full of it.
  5. Jul 10, 2011 at 10:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well, grease actually for lubing the CV joints, You've got a somewhat narrow window of opportunity to R&R the boot without suffering any permanent damage, don't engage your 4x mode & replace CV boot ASAP..;)
  6. Jul 10, 2011 at 10:16 PM
    rcfreak201
    rcfreak201 Well-Known Member
    whats the thing on the stock UCAs? i thought those were boots? like on the under part of the stock uca where the uniball would go on an aftermarket arm because i thought those tear too?
  7. Jul 10, 2011 at 10:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    OOPS DISREGARD
    VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVvvv
    Your talking about those accordian boots for the rack & pinion steering I think, yeah they tear sometimes...
    I read your post wrong, you mean those little grease boots for the ball joints ?
  8. Jul 10, 2011 at 10:21 PM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    I just had a torn CV boot fixed recently, drove with a torn boot for at least a couple of weeks.
    My mechanic just installed a whole shaft kit.
    He says as long as he's in there it's easier just to replace the whole thing.
    Also eliminates the risk of putting a new boot over potentially damaged goods.
  9. Jul 10, 2011 at 10:22 PM
    jblair
    Colorado
    99 taco 2.7L I4
    I think that's the upper ball joint.
    Well then can somebody point me in the direction of a writeup on a cv replacement? Lord only knows how long we've been wheeling with that torn....
    edit: jack is tasty
  10. Jul 10, 2011 at 10:23 PM
    rcfreak201
    sorry to thread jack OP, but yeah doug that, i looked under my UCA and its ripping like kinda coming out, do i need new UCAs? what would happen if it didnt replace it?
  11. Jul 10, 2011 at 10:28 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    sooner or later, they'll dry out, get noisy,get stiff & finally....they'll snap
  12. Jul 11, 2011 at 4:13 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    Because I was too lazy to take on that project, I drove mine like that for a few years. Periodically I would climb under the truck and put grease in it. I think the book is as important for keeping dirt and grime out as it is for keeping grease in. Never had a problem though.
  13. Jul 11, 2011 at 4:49 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
  14. Jul 13, 2011 at 10:37 PM
    jblair
    Colorado
    99 taco 2.7L I4
    thanks facemob, I saw that is that the same process for the 99 manual locking hubs?
  15. Jul 14, 2011 at 4:54 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    not sure about that, didnt notice, sorry. im sure its a bit different.......... ?
  16. Jul 14, 2011 at 11:17 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Probably going to rip your boots again after putting in the 5100s and eibachs. From what I've seen, many people with the eibachs and 5100s with the stock bumper tear their cv boots before the springs settle in some. I think you should leave the cv axle with the torn boot in for awhile after installing the eibachs so the springs can settle in and you don't have to replace a cv axle again pretty quickly. I drove around for a few months with both cv axles having torn cv boots with no problems.
  17. Jul 14, 2011 at 7:54 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    If this is correct (Eibachs settling) this might not be a bad idea & do a diff drop to straighten the CV angle a little...;)
  18. Jul 14, 2011 at 8:04 PM
    magic
    magic Well-Known Member
    sorry for thread jacking but im thinking of going with eibachs and 5100's.
    if i was to put on some long travel cv boots or do they cv boot mod and put a diff drop would i be spared from the boots being ripped when i lift my truck?
  19. Jul 14, 2011 at 8:09 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well it'll reduce the incidents of boot tears & they'll last longer, but you're not going to be "spared" You just won't be changing them as often, also depends how much wheeling you do..
  20. Jul 14, 2011 at 8:13 PM
    magic
    good point... so has anyone done that cv boot mod?
