CV help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trucko, Aug 28, 2017.
  1. Aug 28, 2017 at 9:56 AM
    Trucko
    Trucko [OP] Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    I am having a hard time getting a video of the sound coming from my truck but my gut tell my it's my cv. Question for TW is what does a failing CV sound like. The boots are in tack and no grease or visible issues just an intermittent sound. Thanks
  2. Aug 28, 2017 at 10:41 AM
    Pigpen
    Dan
    Northwest Montana
    CVs will make a click-click-click-click noise when you turn if they're going bad. Is that the noise?
  3. Aug 28, 2017 at 10:41 AM
    Trucko
    2005 Tacoma
    Yep close enough
  4. Aug 28, 2017 at 10:42 AM
    Trucko
    2005 Tacoma
    Like a metal clicking sound
  5. Aug 28, 2017 at 10:49 AM
    Pigpen
    Dan
    Northwest Montana
    yep. Put OEM axles in it if you want them to last. Reman axles from CVJ with high angle boots are a good call if you're lifted and wheel it or overland
  6. Aug 28, 2017 at 10:51 AM
    Trucko
    2005 Tacoma
    I'm assuming I should just replace both of them upfront instead of just one and I have not even searched yet but how much does a CV cost
  7. Aug 28, 2017 at 10:53 AM
    Pigpen
    Dan
    Northwest Montana
    OEM is like $300
    Yes, do both
  8. Aug 28, 2017 at 10:55 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Jack the truck up, turn the wheel full lock and spin the tire by hand to see if you can make the same noise.
  9. Aug 28, 2017 at 10:55 AM
    Trucko
    2005 Tacoma
    Is your username from the movie out cold and thanks for all the help
  10. Aug 28, 2017 at 10:55 AM
    Trucko
    2005 Tacoma
    Perfect thanks great advice before I buy parts
  11. Aug 28, 2017 at 10:59 AM
    Pigpen
    Dan
    Northwest Montana
    Summit County is a beautiful place. Lived in Breck for a year. Spent the summer living out of my truck while working full time and worked for the ski area in the winter 2001-2002.
    Montana sucks. Never move to Montana.
  12. Aug 28, 2017 at 11:00 AM
    koditten
    Kirk
    Central Michigan
    I have family there, is it ok to visit?
  13. Aug 28, 2017 at 11:08 AM
    Trucko
    2005 Tacoma
    Yes you can visit but please if you enjoy the views stop and get out of your car instead of trying to take pictures when you drive. Im getting so sick of people not bing able stay in their lanes while they look out the windows
  14. Aug 28, 2017 at 11:27 AM
    Trucko
    2005 Tacoma
    Can I assume I can buy OEM from rockauto
  15. Aug 28, 2017 at 11:37 AM
    Pigpen
    Dan
    Northwest Montana
    Pretty sure dealer only. Try Camelback Toyota Parts
  16. Aug 28, 2017 at 11:39 AM
    Pigpen
    Dan
    Northwest Montana
    They're a vendor on here. @CBT_Brian can help
  17. Aug 28, 2017 at 11:40 AM
    koditten
    Kirk
    Central Michigan
    It may only need grease. Get a grease needle and inject it full of grease. Clicking is not the same as broken.
  18. Aug 28, 2017 at 11:44 AM
    evoviii1220
    evoviii1220 Well-Known Member
    Dan
    NJ
    05 4x4 DCSB
    Silver touch up paint
    I don't think it's common for the oems to go unless you run them out of grease for many miles or have an insane lift. How many miles on them? My 05 still has the originals, coming up on 150k. Other than re booting them a few times they are perfect.
  19. Aug 28, 2017 at 4:47 PM
    Trucko
    2005 Tacoma
    160k and the noise started in Moab when it was 100 degrees in bull canyon. drove home and back in the cold mountains sounds goes away. Noise came back only after driving through the river. What is "needle grease" and where can i get some. link please. i do have a chepo grease gun will that work?
  20. Aug 28, 2017 at 4:50 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    No OEM from Rock Auto, those will all be aftermarket parts. CVJ Reman is local to you in Denver, the most expensive part for me switching out was shipping.
