CV housing tolerances
Discussion in 'Technical Chat' started by JBOND, Jul 6, 2011.
  1. Jul 6, 2011 at 2:59 PM
    JBOND
    JBOND [OP] New Member
    G.ville Fl.
    06 Pre-runner ext Cab TRD
    Here's the problem. I have an 06 Taco 4X4 V6 TRD. I recently noticed a humming noise (like tire hum) and slight vibration. I think it's coming from the front end. I have checked the CV joints and the left housing appears to be loose. The tripod is tight in the housing but the housing moves side to side and in and out about 1/8th inch. Does anybody know if there are any tolerances for this? Any comments/suggestions would be appreciated.
  2. Jul 6, 2011 at 3:35 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check your wheel bearings for free movement, slop, and movement. If it feels like there's sand or gravel in there, or there is excessive movement, replace them.
    You can tell when it's a bearing by going around corners. If it goes away on a left turn and not a right, it's a bearing going bad, and vice/versa.
