CV install whoops
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MAG GRY TACO15, Nov 6, 2023.
  1. Nov 6, 2023 at 9:34 AM
    MAG GRY TACO15
    MAG GRY TACO15 [OP] Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
  2. Nov 6, 2023 at 9:41 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Yes, it sounds like you've fixed it.
  3. Nov 6, 2023 at 1:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, it is normal for the axle to slide in and out of the differential a small amount.
    It is doing exactly as you described. When pulling it out, the C-clip stops it from coming out further. It stops against the back side of the spider gear.
    When I put them back in, I do just as you are doing. I pull back out on the CV and make sure it "stops" on the C-clip.
    Then I press it in all the way back in and call it done.
    MAG GRY TACO15[OP] and winkel like this.
  4. Nov 6, 2023 at 3:59 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You should be fine now, just keep an eye on it to see if it boogered up the seal when it came part way out. If it's not leaking, you're fine.
    MAG GRY TACO15[OP] likes this.
  5. Nov 6, 2023 at 4:39 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    yea you should be fine now. You might see some residual dripping for a day. But super minor stuff. Just saying, you might still see something so don't be alarmed.
  6. Nov 7, 2023 at 5:22 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I did see a drip after my test drive yesterday. I got worried but wiped it off and was gonna check it daily for a few days. Hopefully it won't return
