CV joint field repairs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bushman31, Sep 15, 2023.
  1. Sep 15, 2023 at 5:02 PM
    bushman31
    bushman31 [OP] Well-Known Member
    Ron
    Draper, UT
    TRD
    Old Man EMU suspension, 33" tires, 4.56 gears, Leer shell, airlift airbags, Fab 4's rear bumper and tire carrier, and some other shit.
    Has anyone done a write up on removing a broken cv joint/axle or replacing tie rods out in the field while off-roading? I have been searching the forums but haven't been able to find anything.
    Thanks for any assistance,
    Ron Wilkinson
  2. Sep 15, 2023 at 5:17 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Would it not be the same as to it being in a shop/ garage?
    More importantly are you currently stuck in the field with a broken CV?
    theesotericone likes this.
  3. Sep 15, 2023 at 5:18 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    It's done the same way as you do it in the garage. Just more uncomfortable.
  4. Sep 15, 2023 at 5:23 PM
    bushman31
    Ron
    Draper, UT
    TRD
    Luckily I am not currently stuck but I am wondering if something would be done differently since I wouldn't be doing a replacement out there, just removing the broken cv joint to get back home.
    Ron W.
  5. Sep 15, 2023 at 5:34 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Biggest issue if you have to remove the axle and don't have something to put in it's place you can have issues. You need the stub shaft going through the wheel bearing, and with out the inner shaft your diff will be leaking oil. I know some people keep shaft ends in their truck for that reason incase something happens to their CVs and they want to take them out so they can be rebuilt but still drive the truck in the mean time.
  6. Sep 15, 2023 at 5:38 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Assume you mean how do you keep going if way out there alone and a CV breaks. Some carry a spare. New Napa shafts about $125. Same with tie rods carry a spare.
    Both ends need to remain in so you would have to remove the center shaft part destroying the boots and CVs.
    Front diff would empty out without it and wheel bearing is supported by it.
    So no 4wd at that point anyway first try 2wd and see if you can drive out with it as is or if 4wd required to get out you got to go get a new one.
    See you are in UT and lower gears bigger tires. Don't forget spare U-joints. Watch out for full throttle climbs and a big bounce as that can break the ring and pinion - been there.
    Hard to plan for everything. By the time I got out didn't have too many teeth left on them. Still a fun trip.
    Marc70 likes this.
  7. Sep 16, 2023 at 4:48 PM
    bushman31
    Ron
    Draper, UT
    TRD
    Thanks guys for the help. I will get a spare cv/axle.
    Ron W.
    Marc70 likes this.
