CV joint is shot???? NEED some help
Discussion in 'Suspension' started by 05tacoSPORT, Sep 6, 2010.
  1. Sep 6, 2010 at 7:18 PM
    05tacoSPORT
    05tacoSPORT [OP] Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I have 3in lift coils with stock shocks and TC uca. Also installed a front diff drop. First ? is can i get 5100's and set them at 0 and get more down travel and a better ride white keeping the same lift? 2nd ? is my cv joints are clicking:mad: They will click over bumps / when turning / getting in and out of parking spots / and REALLY F ing pop while off road on rough ground. I have checked my boots and no leaks or cracks but my inner boots are not gonna last too much longer. Also there is some play in the shafts. I can push and pull them making them move slightly. I have a 100k warranty on the truck but will toyota fix my problem? If not should i save and get RCV cv axles made for severe angles? they are 600 a pop :eek: Can i pull the axles and repack with grease and new boots? :D Back the the 5100's my lift coils have a 1/2 in spacer that i want to put in the trash so what would i set the billies at? Running 285/75/16 tires. I gonna shut up now but want to here what you have to say. CHRIS 4X4 can chime in also.
  2. Sep 6, 2010 at 7:50 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    that helps did you have any clicking before they "shit the bed"
  3. Sep 6, 2010 at 9:04 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yup less than 3 inches. :p
    Edit: wait im retarted
