CV Joint moving!!
Discussion in 'Suspension' started by owen06, Sep 5, 2011.
  1. Sep 5, 2011 at 10:54 AM
    owen06
    owen06 [OP] Well-Known Member
    Hinesville, GA
    16 DCSB 4x4 Red
    Hey guys,
    I went to take off my sway bar today and I found a bunch of splattered grease on and around my driver side CV joint where it meets the diff.
    After wiping it all off, I checked the CV boot for tears or cracks and found none. Then I checked the shaft. I found I was able to move the shaft about an 1/8", side to side, from where it meets with the differential.
    The pass. side does not move. So I am assuming the grease is coming from that gap where the CV shaft meets the diff.
    This is on a 09 DCSB with a 6" Fabtech lift.
    I had sort of the same issue with the carrier bearing, where the nut had backed off after the lift and it shredded the bearings. But they don't mess with the shafts when doing the lift right? They did re-gear, so was there disassembly with that?
    What do the internals look like? Is there a nut in there that may have come loose?
    I'll have to take it to the dealership on Wednesday unless I can find a fix here.
    - Josh
  2. Sep 5, 2011 at 11:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    SIde to side meaning "in and out" of the diff housing?
  3. Sep 5, 2011 at 11:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    CV joints look like one of the two types here:
    There are no internal nuts
  4. Sep 5, 2011 at 11:03 AM
    owen06
    Hinesville, GA
    16 DCSB 4x4 Red
  5. Sep 5, 2011 at 11:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    The movement is normal, however it looks like the oil seal popped out. You should pull the fill plug and see if the fluid level is low.
  6. Sep 5, 2011 at 11:11 AM
    owen06
    Hinesville, GA
    16 DCSB 4x4 Red
    I'll check it. My only concern is that grease was splattered, not oil.
    I have to drive back home today, 120 miles. I should hold until I get back and I can look at it there or take it to the dealership. I don't have time today to fix it unfortunately.
  7. Sep 5, 2011 at 11:53 AM
    owen06
    Hinesville, GA
    16 DCSB 4x4 Red
    Is this something an installer would have to mess with to either install the lift or install new gears?
    If not, I should be able to claim this under warranty.
  8. Sep 5, 2011 at 11:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    An installer would have to remove the axles for a gear change not the lift.
  9. Sep 5, 2011 at 12:16 PM
    98tacoma27
    Ben
    Not Beech Creek
    To sort of correct myself, they would only need to take the driver side axle out to get the third member out to swap gears.
  10. Sep 5, 2011 at 12:21 PM
    jandrews
    '09 FourDubDee TRD OR
    Could be a loose boot clamp as well. Check that.
  11. Sep 5, 2011 at 5:35 PM
    owen06
    Hinesville, GA
    16 DCSB 4x4 Red
    I checked the boot pretty well. Didn't see anything loose, torn, or cracked.
  12. Sep 5, 2011 at 5:43 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I put a lift on my 2000 tundra and the pressure of the cv angle made the cv grease come out the boot ends with out tearing the boots. The fix for that was putting hose clamps on the boot ends to keep them from leaking. This eventually ended up in the hose clamps tearing into the boots but it's better than loosing all your grease right away. I put after market axles on that tundra after all that and they wouldn't leak out grease with the lift. So use some hose clamps for now til you find a more permanent fix.
  13. Sep 5, 2011 at 5:44 PM
    owen06
    Hinesville, GA
    16 DCSB 4x4 Red
    It was a thick brown. Not sure I saw any tint of green.
