CV joints clanking.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacowade, Aug 28, 2011.
  1. Aug 28, 2011 at 1:13 AM
    tacowade
    tacowade [OP] Active Member
    Wade
    deerwood,mn
    95tacoma4x4
    I have had a clanking sound on both sides in the front when going over bumps since I bought the truck and I have been trying to find out what has been causing it. It is a metal on metal type sound. I checked all the bushings and just about everything around the front end and everything was tight except the sway bar links so I replaced them and still have the sound, so I put her on jackstands and removed both wheels. I found out the outer CV housing on both sides are slapping against the steering knuckle on both sides. Is this a common problem and does anybody know how to fix this problem?
  2. Aug 28, 2011 at 2:08 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    :worthless:
    I've heard that clanking in the CVs mean the shafts need to be replaced, but people will chime in once theres some pics of the problem
  3. Aug 29, 2011 at 12:28 AM
    tacowade
    Wade
    deerwood,mn
    95tacoma4x4
    The CV joints do not click or pop while turning either way with or with 4wd engaged, so I doubt that they are bad, I could be wrong. Every front wheel drive I have owned with bad CV joints has clicked or poped while turning. The outer metal case of the cv joint has play that slides back and forth about an 1/16". There is no play up and down. The boots are intact, no rips or tears.
  4. Aug 29, 2011 at 12:30 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    ah. could you take any pics?
    Maybe somethings rubbing?
