CV Question kinda of dumb
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Aug 28, 2020.
  1. Aug 28, 2020 at 4:30 PM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Just curious on how cv axles work if i were to drive and climb a hill on a trail and you give it gas and one tire moves and the other one isnt. the cv would be fine right? unless you were bouncing up and down really fast and snap it then of course that is bad. or if you were to climb a "rock" and need to get your tire moving and need to give it gas enough to start going.
  2. Aug 28, 2020 at 4:33 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Tires spinning together or singular is a function of the differential. If you want them to both spin at the same time you need a locker.
    Black DOG Lila likes this.
  3. Aug 28, 2020 at 4:34 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Front differential is an Open differential.
    So you be ok.
    Unless you got a locker that's not working when on.
  4. Aug 28, 2020 at 4:34 PM
    Allex95
    allex
    whats the chancing of breaking a cv climbing rocks? ik there pretty strong so.
  5. Aug 28, 2020 at 4:59 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Things that will increase your chances of breaking a CV are too much wheel spin and sudden traction, turning the wheels to full lock and too much throttle, a wheel or wheels going up in the air and spinning freely and coming down hard. Like shock loading the driveline.
    I’m probably missing something
  6. Aug 28, 2020 at 5:00 PM
    Allex95
    allex
    Yea that’s what I thought. Just curious to know what not to do when I take a harder trail
    otis24[QUOTED] likes this.
  7. Aug 28, 2020 at 5:06 PM
    Allex95
    allex
    Is is a LSD or a open diff
  8. Aug 28, 2020 at 5:08 PM
    Black DOG Lila
    Virginia
    Open
  9. Aug 28, 2020 at 5:09 PM
    Allex95
    allex
    So would the case of one wheel turning one not happen? Or no because it’s a open diff.
  10. Aug 28, 2020 at 5:13 PM
    otis24
    Mark
    California
    Mainly be smooth with the throttle.
  11. Aug 28, 2020 at 5:17 PM
    Black DOG Lila
    Virginia
    Yes
    The wheel with less traction or in the air will spin
    Open means path of least resistance
  12. Aug 28, 2020 at 5:22 PM
    Allex95
    allex
    Ahh got it I’ve always thought how do you not break something if the wheel isn’t moving
  13. Aug 28, 2020 at 5:38 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Your truck is probably open in the rear as well.. i don't know if they had factory rear locker option in 96 but I don't think so.
    But the same concept applies. When you put it in "4x4" you're technically only 2 wheel drive. One in the rear and one in the front. So if you're ever in a situation where you only have one rear wheel and one front wheel on the ground. You won't go anywhere..the 2 lifted wheels will just sit and spin
  14. Aug 28, 2020 at 5:38 PM
    Black DOG Lila
    Virginia
    Think of it this way
    If your open diff 2x4 has one rear wheel in the air, ice or mud you're stuck.
    If your open diff 4x4 has one front and one rear wheel in the air, ice or mud you're stuck.
    Keep all 4 on good ground as much as possible.
    Or get front and rear diff locks and go rock crawling.
    Abeyancer likes this.
  15. Aug 28, 2020 at 5:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    All this means is the OP needs front and rear lockers....have to compliment those 40s and tons somehow :spending:
  16. Aug 28, 2020 at 5:40 PM
    Allex95
    allex
    Okay So if I’m in 4x4 and climb something and one tire isn’t moving but one is that’s a open diff. Cv wouldn’t get hurt or anything correct? Sorry about dumb questions just never asked about them just wheeled:rofl:
    Abeyancer[QUOTED] likes this.
  17. Aug 28, 2020 at 5:41 PM
    Allex95
    allex
    Soon:rofl:
  18. Aug 28, 2020 at 5:42 PM
    Black DOG Lila
    Virginia
    And NO
    Manually locking front hubs wont change how open diffs perform.
  19. Aug 28, 2020 at 5:42 PM
    Allex95
    allex
    Yea I get that lol.
  20. Aug 28, 2020 at 5:44 PM
    Abeyancer
    Jimmie
    PNW
    Better to ask the questions now!
    You're correct on both parts. However if you're throttling up in that position and you lurch forward (if your back wheels get traction for example) and you come slamming down on that front tire still spinning, there's a high probability of a cv breaking.
    Throttling through wheel hop is a bad idea
    On the flip side there's an offroad saying you'll hear that goes "when in doubt, throttle out" and there's some truth to that as well. It's a double edged sword
    0xDEADBEEF likes this.
