CV Shaft Stuck in diff housing
Discussion in '1st Gen. Tacomas (1995-2004)' started by bearfoot990, Nov 17, 2014.
  1. Nov 17, 2014 at 6:44 PM
    bearfoot990
    bearfoot990 [OP] Member
    My passenger side axle is stuck in the diff housing. Ive tried beating it out, prying it out, and pressing it out. Any other tricks i can try to get it out? The snow is flying and i need my truck back.
  2. Nov 17, 2014 at 7:33 PM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    I always had best luck by making sure the axle was coming straight out of the housing when I pried it out. Like if any of it was not perfectly in line it was a PITA to get it out.
    Usually I just have my lower control arm on a jack, the spindle out of the way and a 2x4or so between the LBJ and shaft to level it out. Then it pries out much easier.
    edit: it's simple but I had hell with one one time till I remembered this.
  3. Nov 17, 2014 at 7:40 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I used a big crowbar to pry them out on both of mine and they popped out easily. A big screw driver isn't stout enough.
  4. Nov 17, 2014 at 7:44 PM
    bearfoot990
    I actually removed the shaft and housing from the diff. 20 ton press would not take it out. I think i may just have to get a new housing and everything. Such a pain in the ass.
  5. Nov 17, 2014 at 8:37 PM
    bearfoot990
    Where is the best place to look for parts?
  6. Nov 17, 2014 at 8:53 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Snap/lock ring hell bit down on it. Betcha that internal ring is welded between the two,,now.
    A fistful of bucks,,but fixable.
    Pry out,, easy slide hammer out. Never hammer in with great force. A few teaser loosening taps maybe,,then pry out. Very limited space in there and it can be a real knucklebuster,,almost better to pull it out at the start,,before you start if your after axles or seals anyway.
    They usually pry right out,,you got a extra special one.
  7. Nov 17, 2014 at 9:03 PM
    bearfoot990
    I think I did get a special one. Then again everything on this truck has been special. I guess I'm gonna hunt down parts. Hopefully it's not too spendy.
    edit: I cant even find those parts. Maybe just a used diff might be easier.
  8. Nov 18, 2014 at 7:40 AM
    CR, WA
    stock
    If you do go to a u-pull-it yard, I would keep my core until the new/used unit rolls down the road. Make sure you snag the right gear ratio. At minimum I would change out the axle seals once it's on your worktable.
  9. Nov 18, 2014 at 9:56 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Kinda weird that little lock ring holding it in would cause so much BS, unless its gotten so hot its now turned into a ridge, or expanded out on the ends of ring causing it to "lock" itself on both sides of the groove it sets in, did you try getting 2 pry bars on it so theres equal pressure when prying out ?
  10. Nov 18, 2014 at 10:28 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Just don't use too much "There Butch".:D
  11. Nov 18, 2014 at 1:45 PM
    CR, WA
    stock
    By the sounds of it,,and 20 ton presses involved,,a end of that ring (or both) popped out and then got drove between the 2 locking grooves on each side.
    Metal wedge drove between. It might be a 30-50 ton press to separate what will be basically junk once apart now. Apparently, that ring material is rated above 20 tons.
    Regardless, something evil happened that shouldn't have.
    Years ago I had a 78 Corolla that had a axle bearing go bad,,and I got the sideways snap ring as the axle started out, but I was able to slide hammer it apart and it came apart pretty easy even tho it was fubar'd.
  12. Nov 20, 2014 at 12:42 PM
    bearfoot990
    I've tried two pry bars and a slide hammer at the same time. It just doesn't want to move. I'm gonna see if I can find a bad diff for cheap and just use the part I need.
