Cv shaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tylertaco123, Jan 22, 2018.
  1. Jan 22, 2018 at 1:23 PM
    Tylertaco123
    Tylertaco123 [OP] Active Member
    having to replace the driver side cv shaft on my 2015 tacoma. Anyone have to do this? Shop cost? And is it easy enough to do at home?
  2. Jan 22, 2018 at 1:24 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    My first question is why do you have to replace it?
  3. Jan 22, 2018 at 1:31 PM
    Tylertaco123
    Had a leveling kit installed awhile back and I’ve started to notice a thumping noise coming from the front end at low speeds. I went under and was wiggling things around and felt that the drive side shaft had a good amount of play and the passenger didn’t. Took it to a shop and they told me that that’s what the problem was
  4. Jan 22, 2018 at 1:34 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Any chance its covered under warranty?
  5. Jan 22, 2018 at 1:35 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  6. Jan 22, 2018 at 2:20 PM
    Tylertaco123
    I haven’t tried to put it in 4wd yet but I did grab ahold of the driver side cv and it has a lot of play in it (Unlike the passenger side)
  7. Jan 22, 2018 at 2:21 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Doesn't mean it is bad do the test in 4WD first and see if the rumble goes away
  8. Jan 22, 2018 at 2:33 PM
    Tylertaco123
    Okay I will try on my way home and let you know.
  9. Jan 22, 2018 at 3:10 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    My 2008 does the same thing and many other people have reported that as well. I think it might be normal. I have no oil leaking out of it.
  10. Jan 22, 2018 at 3:11 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    My 15 has a little play as well on the Driver's side
  11. Jan 22, 2018 at 3:21 PM
    Tylertaco123
    Well I’m just very confused and don’t want to spend the money replacing it if that’s not the problem. I took it back to the ship I got the lift installed at and they took my into the garage and showed me the shaft moving and said that that’s the only thing it could be.... so I’m confused lol
  12. Jan 22, 2018 at 3:23 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Don't be confused drive it in 2 wheel drive, and see if it rumbles. Then put it in 4 wheel drive and see if it goes away
  13. Jan 22, 2018 at 4:59 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Shops want to make money?!
    Extra Hard Taco and WPNZ like this.
  14. Jan 22, 2018 at 5:01 PM
    Tylertaco123
    So I drove home and it still made it in 4wd. But I’ve noticed it doesn’t make he thumping noise until I drive it around for awhile. Almost like it has to warm up first....? idk what to think anymore.
  15. Jan 22, 2018 at 5:12 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    ECGS NEEDLE BEARING ELIMINATOR. Tell your shop to install this for you. Then if the problem doesn't go away which I'm sure it will, then move on to the cv
    WPNZ likes this.
  16. Jan 22, 2018 at 5:44 PM
    WPNZ
    WPNZ Well-Known Member
    Tucson Arizona
    14 DCSB SR5 6MT
    90yota likes this.
  17. Jan 22, 2018 at 5:51 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    90yota likes this.
  18. Jan 22, 2018 at 5:55 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I did the ecgs needle bearing thing.
    Pretty easy if you have the tools and know how to remove the cv
    90yota likes this.
  19. Jan 22, 2018 at 7:15 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    Do the needle bearing as discussed will fix your issue
  20. Jan 23, 2018 at 2:52 AM
    Tylertaco123
    Is there any videos of the sound a bad needle bearing makes? I’ve read some and people describe it as a growling type sound as mine is more of a clunk sound at low speeds. Worth looking into though because I did just get a leveling kit installed and the video says a needle bearing is a common cause after installing a lift.
