CV wear on 3in?
Discussion in 'Suspension' started by Sunner, Nov 9, 2011.
  1. Nov 9, 2011 at 10:05 AM
    Sunner
    Sunner [OP] Well-Known Member
    Hi guys, Im a VERY proud new Taco owner, just picked up an 05 TRD Sport 4x4 6 speed on Sunday, Indigo Ink Pearl color. I have been browsing the suspension section all weekend deciding on a lift. After researching, I decided I will go no higher than 3inches. I was set on the ProComp with a DD and some UCAs after reading the ProComp thread and seeing how happy the guys were with it. Then decided to save a little extra cash and go for the OME or the Ulitimate Lift after seeing some other threads saying how much better they are. Now I know this is probably going to start reading like a very played out and overposted thread but bear with me. I know that the 3inch lift is going to wear down my CVs after reading that everywhere, thats why I wanted the DD. Then I read another thread last night saying the DD does nothing for the CVs at a three inch lift. I personally would rather not wear them down prematurly. So I have been reconsidering going with a Bilstien 2 inch lift with a DD. From what I have collected, that setup should not stress the CVs at all. So my question is, if I do go with a 3in, how long will my CVs last before I have to replace them? Im sure this info is somewhere but I did not come across it and the answers I did come across vary in a large range. If they are going to go out quick, I will just settle with a 2in and a DD, if they last a while, Ill go the full three. Personally I dont think the extra inch will make much of a difference. Any input is appreciated and I thank you in advance. You guys here seem much more accepting and patient with old posts than in other forums im regestered in(e.g Stuntride, those guys tear newbs up). Thanks again.
  2. Nov 9, 2011 at 10:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    You'll be fine CV wise. You don't need the DD on the second gen as the difference is minuscule in angle.
  3. Nov 9, 2011 at 10:13 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    FYI , if you go with the OME kit , I got 2 1/2" with 885 coils , no spacer .
    I didn't install the diff drop , as the concensus is that with 2nd Gens it doesn't really do anything .
  4. Nov 9, 2011 at 10:55 AM
    Sunner
    Allllriighhtt Then, well I guess that is about as much reassurance as I need, I will go with the 3in then, the 2.5 OME doesnt sound bad. I cant expect to go trailing and not have anything wear out or break eventually, that is the mind state that I was stuck in and need to accept the reality of the sport, Ill just deal with any CV problems when and if they come up. Thanks guys.
  5. Nov 9, 2011 at 11:49 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You'll be good man! Just get some quality coilovers and keep them around 2.5"! That'll give you all the benefits you need!
  6. Nov 10, 2011 at 9:38 AM
    Sunner
    Awesome, thanks man, can't wait to get it
