CVT question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dishman88, Aug 30, 2021.
  1. Aug 31, 2021 at 7:41 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    2023 tacoma...CVT...lol
  2. Aug 31, 2021 at 7:53 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    CVT in our Prius, yup. CVT in the Rav4 Hybrid I traded for my Taco, yup. CVT in the Taco, not so much.
    zoo truck likes this.
  3. Aug 31, 2021 at 7:55 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
  4. Aug 31, 2021 at 8:40 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  5. Aug 31, 2021 at 9:09 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Correct. You would have a completely different set of problems.
    The biggest being that you might think that because you operate a simple gear box...you are the equivalent of Albert Einstein
  6. Aug 31, 2021 at 9:10 AM
    Toyko Joe
    Toyko Joe Here for the pictures
  7. Aug 31, 2021 at 9:55 AM
    Tripod1404
    Tripod1404 Annihilator tripod
    Neither of those cars have a traditional CVTs either, they have a power split device that Toyota calls eCVT. eCVT is probably the most reliable transmission on the market.
    HappyGilmore likes this.
  8. Aug 31, 2021 at 10:03 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Learn something new every day! Thanks! :)
  9. Aug 31, 2021 at 10:08 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    adauto10, Gmak621, balljoint and 5 others like this.
  10. Aug 31, 2021 at 10:46 AM
    coma toy
    coma toy Off Road Taco
  11. Aug 31, 2021 at 10:48 AM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    Manual owners are the vegans of the automotive world. They will tell you their transmission preference even if you never asked.
  12. Aug 31, 2021 at 10:54 AM
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    A lot of them do have manual mode that can "downshift"/"upshift" ... like for more engine braking when going downhill or more power in the mountains. Basically it kind of fakes a fixed gear ratio and holds a lower ratio to bring/keep the revs up.
    The Kia one gives a pretty convincing impression and "shifts" faster than many regular automatics I've used
    Skip to 3:40
    gwiz, tonered and Pugga[QUOTED] like this.
  13. Aug 31, 2021 at 10:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    So the transmission with no gears shifts gears faster than many other transmissions with gears except one of the big selling points of the CVT is the smooth power delivery so you don't get the dead spots from shifting gears... :facepalm:
  14. Aug 31, 2021 at 11:07 AM
    adrew
    Leer 100XR
    As I understand it, these Hyundai/Kia ones can do either. Like in normal driving it's smooth/uninterrupted with no shift shock, but in situations where CVTs have traditionally been caught flat on their feet (mountain driving) you can make it behave like a regular automatic. You can keep the engine "on the boil" instead of having it instantly shift back to "top gear" as soon as you let off the throttle a little (like the old Nissans that had the horrible rubber band effect and were horrible to drive in undulating terrain where you're up/down/up/down hills).
    The overall ratio spread in most of them is wider than a traditional 4/5/6-speed automatic to wring the most power out of the modestly-powered engines. So it can have a really short ratio on the low end of the transmission for good power off the line, and a really tall top ratio for relaxed cruising speed.
    In the old days with 4 speed automatics, the top gear had to be relatively short to prevent constant downshifts, so 1.6/1.8-liter cars turned 3500-4000 RPM on the highway. But now with the CVT, it can lengthen itself all the way out on flat land for super low RPMs... our old Corolla only turned 2200 RPM at 80 MPH, great for a 1.8-liter, IMO. But if there is a hill or a strong headwind, it will just shorten the ratio slightly to bring the revs up a little, like to 2500 or 2700 to maintain speed with no harsh/repetitive kickdowns or shift shock.
    gwiz and tonered like this.
  15. Aug 31, 2021 at 11:25 AM
    #35
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Got close to 100k on our prius...that cvt still operates like it had 100 miles on it.
  16. Aug 31, 2021 at 12:02 PM
    #36
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Man,,,, I spent my last 3 years of high school in this crappy underfunded catholic school. We didn’t have any sort of shop class. I had to take religion instead. I think shop would’ve been a little more beneficial to myself.
    RustyGreen and tonered like this.
  17. Aug 31, 2021 at 12:02 PM
    #37
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Any pedal other than the skinny one
    Pugga[QUOTED] likes this.
  18. Aug 31, 2021 at 12:08 PM
    #38
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    CVTs 100% "shift" they're not a fixed ratio. They just have more ratios between their lowest and highest ratio. It's really no different than downshifting a conventional trans to get more mechanical advantage.
  19. Aug 31, 2021 at 12:12 PM
    #39
    Pugga
    Massachusetts
    Oh no, I get it. I'm fully aware of how CVTs operate, they're just a beefed up snowmobile belt drive, thus the :facepalm: regarding 'manual mode' for a CVT...
  20. Aug 31, 2021 at 12:18 PM
    #40
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Manual mode is the only way that I have driven ATs since I was teenager, which includes conventional ATs and our first CVT. I had a hatred of CVTs since a belt driven version was used in our lawnmower as a kid. It was also used as the clutch, which was the biggest part of the failed design. The one in our Subaru has not changed my opinion. I do use the Subaru exclusively in manual mode when I have to drive it as it is easily caught out and confused if left to its own devices. Also, the most responsive engine mode is a stepped setting anyway.
