Cyclical humming/vibration from front end.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johnnyjunk, Jul 4, 2016.
  1. Jul 4, 2016 at 4:46 PM
    johnnyjunk
    johnnyjunk [OP] Lurk more, learn more.
    The Great PNW
    2016 Tacoma TRD Off-Road
    My 2016 Tacoma developed a slight hum/vibration recently. I've done quite a bit of lurking through past threads and am 99.9% certain it is the front drivers side diff bearing. It seems like this was a pretty well documented problem on the 2nd gen trucks. My question is has anyone else run into this issue on their 3rd Gen trucks? Sorry if I missed a thread about this.
  2. Jul 4, 2016 at 4:58 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  3. Jul 4, 2016 at 5:01 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    where and when do you feel it?
  4. Jul 4, 2016 at 5:11 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    New truck=warranty...take it to the dealer and get a verifiable history going on this issue....
  5. Jul 4, 2016 at 5:14 PM
    johnnyjunk
    The Great PNW
    deergetr likes this.
  6. Jul 9, 2016 at 10:51 AM
    johnnyjunk
    The Great PNW
    Well, as I suspected the noise was coming from a failed drivers side needle bearing in the front differential. This was a fairly well known issue with the 2nd gen 4wd trucks. Dealer is replacing the whole front diff under warranty.
    George1441 likes this.
  7. Jul 9, 2016 at 11:07 AM
    aero90
    Hmm sounds like a one off issue. I think you're the first person I've seen, on here at least, have that exact issue on the 3rd gen so far. At least they are taking care of you.
  8. Jul 9, 2016 at 11:17 AM
    splitbolt
    NW Arkansas
    Wow...
    Any plans for an ECGS bushing?
  9. Jul 9, 2016 at 11:28 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Is your truck completely stock, no lift, aftermarket shocks and OEM tires?
  10. Jul 9, 2016 at 3:12 PM
    johnnyjunk
    The Great PNW
    I honestly thought about it. I figured as long as I'm under warranty I'll let Toyota pay for parts.
  11. Jul 9, 2016 at 3:17 PM
    johnnyjunk
    The Great PNW
    Not stock. Bilstein 5100s in all four corners, 1" block in the rear, SPC uppers and a diff drop. Sitting on 275/70/r17s all installed at a reputable 4x4 shop. The only time my lift came up during my conversation with the dealer was when I asked to verify they would be reinstalling my diff spacers.
  12. Jul 9, 2016 at 4:25 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    What were the 5100s set to, 1.75 or 2.5?
  13. Jul 9, 2016 at 8:03 PM
    aero90
    Kudos to the dealer for not immediately dismissing you due to a lift. Wow.
    nickj604 likes this.
  14. Jul 10, 2016 at 12:27 AM
    johnnyjunk
    The Great PNW
    1.75
  15. Aug 7, 2016 at 12:12 PM
    Rb1
    Rb1 Well-Known Member
    Ron
    Kent Wa
    2016 tacoma trd offroad dc
    Just lifted mine with pretty much the same setup. The vibration i feel is not constant. More like on 1second/ off 2seconds. Goes away when put into 4wd. Also was almost unnoticable after 5 minutes of driving. I feel in in the gas and brake pedal or floorboard. Does this sound similar? Most noticable between 35and 40mph.
  16. Aug 7, 2016 at 12:14 PM
    Chris.taco.2016
    Chris.taco.2016 Well-Known Member
    2016 Tacoma trd sport mgm dclb
    Need ecgs bearing fix
  17. Aug 7, 2016 at 12:15 PM
    Rb1
    Ron
    Kent Wa
    Whats that?
  18. Aug 7, 2016 at 12:19 PM
    johnnyjunk
    The Great PNW
    Yes, that describes exactly the same issue I was having. I had my front diff replaced under warranty and that fixed it for about 100 miles. Im starting to notice it again though. Not as bad and it goes away after a couple minutes of driving. Before my diff was replaced I could feel it in the gas peddle and it annoyed the shit out of me. I will probably go with the ECGS bushing to replace the needle bearing at this point.
  19. Aug 7, 2016 at 12:20 PM
    johnnyjunk
    The Great PNW
  20. Aug 7, 2016 at 12:24 PM
    Chris.taco.2016
