cylinder 1 and 4 misfire help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Instant, Dec 10, 2018.
  1. Dec 10, 2018 at 7:02 PM
    Instant
    Instant [OP] Member
    Seth
    98 single cab short bed Tacoma 2.7 4x4
    2 inch lift
    I have a 98 tacoma 4wd standard with a 2.7 the truck has 265k but has been well maintained. and have a rough idle and check engine light on. When I had the codes read they showed cylinder 1 and 4 misfire. I have replaced spark plugs wires coil packs, cleaned the MAF sensor. I don't notice any loss of power and the truck hasn't stalled out. I only noticed because of the slight shake when idling after warming up and then the check engine light coming on. What else could it be?
  2. Dec 10, 2018 at 7:09 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Clean the throttle body too and check your spark plug wires
  3. Dec 10, 2018 at 7:13 PM
    Instant
    Instant [OP] Member
    Seth
    2 inch lift
    Ive replaced the wires, how would I clean throttle body?
  4. Dec 10, 2018 at 7:20 PM
    UnderFire
    UnderFire Well-Known Member
    There is a ground on the coil pack bracket, make sure it's clean and making good contact.
  5. Dec 10, 2018 at 7:21 PM
    Instant
    Instant [OP] Member
    Seth
    2 inch lift
    Okay I will double check that, little things tend to get over looked haha
  6. Dec 10, 2018 at 7:23 PM
    UnderFire
    Right, might as well check all 3, theres one right behind the power steering pump bolted to the lower intake manifold and one on the exhaust side of the head all the way at the back towards the firewall, usually bolted on with the bracket for the engine harness.
  7. Dec 10, 2018 at 7:26 PM
    Instant
    Instant [OP] Member
    Seth
    2 inch lift
    And these are coil packs you are referring to?
  8. Dec 10, 2018 at 7:27 PM
    UnderFire
    The engine harness grounds.
  9. Dec 10, 2018 at 8:08 PM
    Instant
    Instant [OP] Member
    Seth
    2 inch lift
    Okay awesome didn’t know the grounds could cause misfire
  10. Dec 10, 2018 at 11:21 PM
    UnderFire
    Bad grounds can cause all kinds of stuff. Brother's truck had an intermittent no start recently caused by some corrosion on one of em. The ECU doesn't like having a weak ground.
  11. Dec 11, 2018 at 8:23 AM
    Glamisman
    Glamisman Well-Known Member
    do a compression check. She needs to be mechanically sound first. If the compression has differences greater than 10% between any cylinders she is going to need that fixed first.
    MacGyvR likes this.
  12. Dec 11, 2018 at 9:42 AM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Fuel injectors are a possibility too, though not likely both 1 and 4 go at the same time, but possible.
    If that’s something you want to check you can swap the injectors from cylinders 2 and 3 with 1 and 4, just be sure to put new o rings on them, they’re cheap.
    If the misfires move to cylinders 2 and 3, there’s your issue. In the future, instead of replacing all of your coil packs you can use this method instead of throwing parts/money at it.
    If it’s not the issue no big deal, truck stays the same but you can rule those things out easily.
    wongdoing likes this.
  13. Dec 11, 2018 at 12:39 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    x2 on the compression test. Could be a failed head gasket or cracked headers. Easy enough to do, you can borrow the tools from autozone too. I'd also recommend pulling the plugs for a quick check, but I'm pretty paranoid after reading all the blown HG posts :der:
  14. Dec 11, 2018 at 6:18 PM
    Instant
    Instant [OP] Member
    Seth
    2 inch lift
    That's my worst fear i have a compression test tool in the truck that's what i was going to do to start and see if there any work needs to be done on the top end. How would i check the compression and what are the ranges they should be st for each cylinder. I've replaced exchause manifold and got my exhaust flange welded had a couple cracks. The check engine light is the last thing i need to be fixed on it so I'm anxious
  15. Dec 11, 2018 at 8:15 PM
    UnderFire
    From my experience the RZ motors tend to lose head gaskets between the coolant passages and one cylinder, so maybe you'll be lucky, I don't remember what the compression is supposed to be, I'd expect like 160ish, but it'll be quickly apparent if you have an issue in a cylinder.
  16. Dec 11, 2018 at 8:17 PM
    Instant
    Instant [OP] Member
    Seth
    2 inch lift
    Do I turn the engine over to check the compression once the tool is plugged into spark plug socket ?
  17. Dec 11, 2018 at 8:20 PM
    UnderFire
    Yep, just unplug your coil pack harnesses and screw in the tester snug, crank 6-7 times per cylinder.
  18. Dec 11, 2018 at 8:34 PM
    Instant
    Instant [OP] Member
    Seth
    2 inch lift
    And if the compression is low in those two cylinders the heads need to be rebuilt ?
  19. Dec 11, 2018 at 11:54 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The compression test should be done with a warm engine and holding the throttle fully open (gas pedal floored).
  20. Dec 12, 2018 at 12:47 PM
    UnderFire
    Youd be losing compression somewhere, rings, valves, head gasket, anywhere is possible.
