cylinder 1 misfire help 2.7 2011 260,000 miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wdissident, May 21, 2022.
  1. May 21, 2022 at 5:12 PM
    wdissident
    wdissident [OP] Well-Known Member
    chris
    orange, cali
    2022 trd sport
    hey everyone haven't been on in years. my truck is pulling up on 260,000 miles and im throwing a p0301 (cylinder 1 misfire)
    I've replaced all spark plugs with ngk (gapped .44)
    I've replaced coil pack and swapped it.
    I've used fuel injector cleaner.
    not sure if i should swap the fuel injectors or if this is an ecu problem?
    symptoms are... Hard start for 1-2 seconds. then idles good and runs good under load.
    any help would be appreciated. thank you again
    all the mechanics are surprised I've put so many miles on it lol
  2. May 21, 2022 at 5:13 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    or
    maybe try seafoam?
  3. May 21, 2022 at 5:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you physically checked for spark at the plug?
    Also, does this ONLY happen on start up?
    And does it NOT misfire after start up?
  4. May 21, 2022 at 5:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Have you ever replaced the valve cover and spark plug tube gaskets?
  5. May 21, 2022 at 6:37 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    neither. the coil pack comes with a tube gasket if that's what you're talking about.
  6. May 21, 2022 at 6:39 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    yes only at start up! super weird. i def have spark at the plug it would shake like shit if i was running off 3 cylinders, right? but have i phsyically checked it with an ohm reader? i have not. i just figured it would shake all the time if that was the case.
  7. May 21, 2022 at 6:40 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    and only for the first second or so^
  8. May 21, 2022 at 6:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Hard starts typically lead me towards headgasket leaks.
    Pressurized coolant slowly leaks into the cylinder and fogs it up, it is very slow, but causes a rough start and the engine light to come on.
    It's tricky to diagnose, we usually use a camera to watch it happen.
    b_r_o likes this.
  9. May 21, 2022 at 6:48 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    would i see coolant buildup ontop of cylinder by using a boroscope inside the spark plug opening?
  10. May 21, 2022 at 6:49 PM
    Bishop84
    It usually appears like a fog, you have to reference a good cylinder vs the bad one.
    Sometimes there's droplets, but usually thats later on when the headgasket is properly leaking.
  11. May 21, 2022 at 6:50 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    without knowing the actually problem, would you throw some headgasket leak sealer in it or any cheap remedies? not super mechanically savvy just handy
  12. May 21, 2022 at 6:55 PM
    Bishop84
    I'm a professional and I would sooner deal with having a rough start before I poured in the stop leak. It causes a lot of other issues with the cooling system.
    We don't know if it is a headgasket, but they don't get better, you can usually spot a puff of white smoke on start up as it gets worse.
    It could be a valve wiring etc.
    ECU is least likely. I have changed very few Toyota ECU's in my career. They are near infallible.
    Steves104x4 and TnShooter like this.
  13. May 21, 2022 at 7:10 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    ok thanks, appreciate fast response. is the spark plug harness the same wires that lead to the valve wiring? is replacing the harness even a thing?
  14. May 21, 2022 at 7:11 PM
    Bishop84
    Sorry missed a comma
    Valve, or wiring. Burnt valves can be spotted with cameras as well. Less likely.
    Wiring can be detected sometimes by wiggling the loom and connectors along the path.
  15. May 23, 2022 at 6:10 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does the coolant level drop slowly over time?
  16. May 23, 2022 at 6:16 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    The valve cover has tube gaskets
  17. May 23, 2022 at 9:27 AM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    I got the same problem with mine. I have low compression on cylinder 1. Could be lots of things running from valves or piston rings needing to be replaced. I'm having a mechanic tear into mine Friday to find out what the problem is.
  18. May 23, 2022 at 10:05 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    the coolant reservoir doesn't get lower.
    i figured if i have/had low compression in cylinder 1 i would feel; but then again what do i know. lol
    but ya i should really test the compression for cylinder 1 to be honest. or at least take an ohm reader to my harness.
    pulled battery to clean throttle body and the check engine light came back after just 12 miles.
  19. May 23, 2022 at 10:10 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Step 1 compression test. It's free if you rent the tool. Or just buy one for $20.
  20. May 29, 2022 at 1:50 PM
    wdissident
    chris
    orange, cali
    2022 trd sport
    wanted to thank everyone. i managed to get rid of the light with some fuel injection cleaner. with this market im going to sell it while it still runs. 260k on this truck as a second owner has been a mile stone.
    just ordered a 2022 tacoma trd sport. thanks again everyone
    Steves104x4 likes this.
