Cylinder #1 misfire
Discussion in '4 Cylinder' started by sdssk8, May 13, 2013.
  1. May 13, 2013 at 4:27 PM
    sdssk8
    sdssk8 [OP] New Member
    California
    2001 Prerunner 4 cylinder, 2.7L
    This may be a dumb question but which one is the #1 cylinder on an 01 4cyl, closer to the front of the car or towards the driver
  2. May 13, 2013 at 6:44 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    The front cylinder is the #1.
  3. May 13, 2013 at 6:53 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    Sparkplug!
  4. May 16, 2013 at 5:52 AM
    goldstar
    goldstar Member
    Joe
    Pa
    2004 Tacoma
    just changed my plugs and still have a misfire ...Duh... HELP...PLEASE
  5. May 16, 2013 at 3:57 PM
    sdssk8
    California
    So I replaced the spark plugs about 2 months before this misfire problem began, I looked at the plug it seems fine and I replaced the coil. Still have the misfire, I want to replace the wires but I'm not sure how to go about it, is it just a harness on each end or is it a pain in the ass to do. Any suggestions
  6. May 16, 2013 at 4:39 PM
    Taylor
    Taylor Wants to learn all about his Taco.
    Taylor
    Lynchburg/Harrisonburg Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
    Are you sure it's not a batch of bad gas?
  7. Jun 3, 2013 at 10:51 AM
    JHG57
    JHG57 Active Member
    James
    Oviedo, Florida
    Mine did that years ago, it was a pinhole in the plug-wire allowing the voltage to bleed off.
  8. Jun 3, 2013 at 2:54 PM
    gcoates
    gcoates Member
    Try using ETHONOL FREE GAS - had the same problem,,,,,,,,,seems the ethoh in the gas draws water into your engine. Put ethonol free gas in my truck and now it dose not spit or sputter like before............ I was surprised.......... go on puregas.org to find closest place that sells this gas.
