Cylinder 1 misfire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CJ303, Aug 18, 2023.
  1. Aug 18, 2023 at 9:54 AM
    CJ303
    CJ303 [OP] Member
    2006 Silver Tacoma 4x4 Access Cab
    History truck has 259k no issues in my ownership and was owned and maintained by a mechanic at Toyota dealership prior to me. 7months ago cylinder 3 misfired and I was loosing power badly. I Replaced the coil and it went away about 6 months later cylinder 4 misfires. then a week later cylinder 2 misfires not as bad and only on ignition or high rpm’s. I decided to Replaced all the plugs and added 3 new coils.
    Currently have all new NGK plugs and all new NGK coils Cylinder 1 is misfiring. I have also run 2 tanks through with STP fuel injector cleaner mixed in and it hasn’t helped. Today I’m going to move the coil and see if it’s faulty but I doubt a NGK coil with less that 1k miles on it would go bad.( I’ll update this post after testing) Any ideas on what I should check next? Injectors? Valve gasket? What do y’all think?
  2. Aug 18, 2023 at 9:57 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    You need to swap coils take one from a cylinder that is working fine and put it in the number one piston with the misfire and see if it moves
    HondaGM likes this.
  3. Aug 18, 2023 at 10:07 AM
    CJ303
    CJ303 [OP] Member
    That’s the test I’m going to do. Update y’all soon
  4. Aug 19, 2023 at 3:46 PM
    CJ303
    CJ303 [OP] Member
    For now the misfire on Cylinder one is gone. I also added some sea foam to help clean everything out. Now when I’m driving the engine get up to high RPM 4-6 with little acceleration until I let off and let the RPMs settle. Only happens in 2nd and 3rd gear. Slipping transmission?
  5. Aug 19, 2023 at 6:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Denso is OE coil
    I’m not saying you have a bad coil.
    But it also wouldn’t surprise me either.
    Swap coils and see.
    But it seems you have a history with misfires.
