Cylinder 2 misfire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06prerandevil, Oct 8, 2019.
  1. Oct 8, 2019 at 9:26 AM
    06prerandevil
    06prerandevil [OP] Member
    Ray
    2006 red tacoma
    Cylinder 2 misfire changed coil packs and spark plugs still shaking like a raped date any ideas
  2. Oct 8, 2019 at 9:29 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Number of things. Wiring/connector on said coil pack, bad fuel injector/no pulse, wiring to said fuel injector, damaged valve(s).
  3. Oct 8, 2019 at 12:24 PM
    06prerandevil
    Ray
    2006 red tacoma
  4. Oct 8, 2019 at 12:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you check the Spark Plug?
    If you’ve replaced it with a known GOOD coil.
    And known good Spark Plug, I’d move to the fuel system next.
    Although it still could be an ignition issue. But it’s not likely since power failure TO the coil is not common. Typically it’s total power loss to all coils, not just one, In my experience.
    Jimmyh likes this.
