cylinder 2 misfires
Discussion in 'Technical Chat' started by waz, Dec 26, 2017.
  1. Dec 26, 2017 at 12:35 PM
    waz
    waz [OP] Member
    chad
    2004 Tacoma 2.7 later cylinder
    1. Hi there havingsome issues with my 2004 Toyota Tacoma 4 cylinder 2.7 liter
    Recently the check engine light popped on and read cylinder 2 and 3 were missfireing.. I swapped coil packs in got cylinder 3 corrected
    Cylinder 2 still is acting up..truck drives fine to me but when idling after 2 min or so starts to idle Rough
    I swapped injector 1 with 2 and cylinder 2 still showing misfiring. I Also have power in the harness to the injectors light does periodically pop off but quickly returns no antifreeze in engine oil Either any help? Thx
  2. Dec 26, 2017 at 12:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the spark plugs?
  3. Dec 26, 2017 at 12:42 PM
    waz
    waz [OP] Member
    chad
    sorry forgo t to mention plugs have been changed after check engine light plugs were jsk, with no response, engine Has 235,000I change the oil regularly
  4. Dec 26, 2017 at 12:48 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Ignition module?
  5. Dec 26, 2017 at 12:52 PM
    waz
    waz [OP] Member
    chad
    Not much of a mechanic but know some basics not exactly sure what that is but I assume they go bad?we did however clean the sensor between the air filter in the throttle body
  6. Dec 26, 2017 at 12:53 PM
    waz
    waz [OP] Member
    chad
    not sure if that's what you're referring to
  7. Dec 26, 2017 at 12:57 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Cleaning the mass airflow is good. Edit: You said it runs rough after sitting and idling. I am probably wrong but I had a problem like this in the past and it was the EGR solenoid but don’t take my word for it. Good luck, Man!
  8. Dec 26, 2017 at 2:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check for vacuum leaks and change your fuel filter.
  9. Dec 26, 2017 at 3:19 PM
    waz
    waz [OP] Member
    chad
    OK I'll keep probing thank you
  10. Dec 26, 2017 at 3:29 PM
    waz
    waz [OP] Member
    chad
    I should mention I unplugged cylinder 1 fuel injector while it was runing and engine had and a significant Response but didn't notice much change when did this to the troubled cylinder number 2 minor difference and ran just about the same unplugged
  11. Dec 26, 2017 at 4:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Bad injector?
  12. Dec 26, 2017 at 4:38 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Verify if you are getting spark on that #2 spark plug/wire.
    wilcam47 and Torspd like this.
  13. Dec 26, 2017 at 5:08 PM
    waz
    waz [OP] Member
    chad
    I p ut an ohmmeter on it and tested the plugs to the injector On cylinder 1 and cylinder 2 they both had the same number reading which I assume is telling me that both are getting an equal amount of currentI even switched injectors to see if I can get the injector to follow and move to cylinder one but it didn't ..even with a good injector Incylinder 2 it still misfire so I'm assuming it's not a injector issue??again I'm no mechanic just thinking out loud
  14. Dec 27, 2017 at 9:57 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Earlier this year, I was chasing a misfire on a Ford Ranger 3.0. I checked fuel pressure at the pump and also at the rail. I checked current at each injector as well. I listened to the injectors for ticking using a stethoscope from Harbor Freight. It wasn't until I pulled the injectors to check flow on each that I found that even though everything seemed to be working, one was not opening when I manually checked the flow on the injectors. (There are youtube videos on how to clean them using a carb spray cleaner and hose).
  15. Dec 27, 2017 at 10:00 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    does it have coil packs or one coil? Id check the wire going to cylinder 2 and also get a pressure check on #2.
  16. Dec 27, 2017 at 3:12 PM
    waz
    waz [OP] Member
    chad
    Yes coil packs.. I put a brand new one in cylinder 2 so that's out of the questionand pulled and injector from a good cylinder and put it into cylinder 2 and it's still acting up so I'm assuming it's not an injector issue I do however hear a sucking sound when the truck is runningI can't tell if I'm hearing the misfire In the catalytic converter or Manifold or am I really hearing a Vacuum leak?
  17. Dec 27, 2017 at 4:07 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    This. Pressure check would be the next step to find out if you have a bad cylinder.
  18. Dec 27, 2017 at 9:39 PM
    wilcam47
    Will
    Bourbon state
    also any loss of antifreeze or oil mixed with antifreeze or oil in the antifreeze? If you are losing antifreeze could be a bad head gasket and losing pressure.
  19. Dec 28, 2017 at 4:30 AM
    waz
    waz [OP] Member
    chad
    Worse case scenario anyone know how much to replace ..
    A bad cylinder?
    Head gasket?
    Truck gas 235000 on it is it worth replacing ?or driving till engine goes and look for a new truck?
  20. Dec 28, 2017 at 5:29 AM
    waz
    waz [OP] Member
    chad
    I've also been noticing an exhaust smell inside the cab when my Heats on or just in general iS this indication of anything?I know it's obviously an exhaust leak possibly manifold would just throw up cylinder 2 misfire
