Cylinder 3 misfire. Diagnosis steps
Discussion in '1st Gen. Tacomas (1995-2004)' started by August425, Aug 7, 2023.
  1. Aug 7, 2023 at 10:05 AM
    August425
    August425 [OP] Member
    Auggie
    2000 Toyota Tacoma Manual 4Cyl 4wd
    Hello fellow 1st gens. I have a 2000 Toyota Tacoma SR5 4 cylinder 2.7L and have had misfires on my 3 cylinder code P0303. I have replaced the spark plug and coil yet I’ve continued to get a check engine light after clearing the code with OBD. I was curious what my next steps might be. My local Napa Technician suggests looking at the pucks on my valves and seeing if it needs to be adjusted or replaced. Could a deep cleaning of the valve cover also be the issue or could it be lack of compression. I’m about to run a compression test to narrow down the results, but would appreciate any feedback. Thank you
    HondaGM likes this.
  2. Aug 7, 2023 at 10:07 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    A quick leakdown test yet?
  3. Aug 7, 2023 at 10:14 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I know you said you already got a new coil, but just a quick check you could swap #3 coil with another cylinder, clear the code, and see if the misfire follows cylinders. If it stays in 3 I'd check the injector for #3 cylinder next.
    HondaGM and Clearwater Bill like this.
  4. Aug 7, 2023 at 10:42 AM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    I second that. Could be looking at a valve/head issue.
    HondaGM[QUOTED] likes this.
  5. Aug 7, 2023 at 10:45 AM
    Bishop84
    Bishop84 Well-Known Member
    I'd consider compression and leak down, but before buying any tools simply swap the injector first. Also if you have a pen light, take a look into the cylinder.
    Does the spark plug show any moisture? burning? etc.
    HondaGM likes this.
  6. Aug 7, 2023 at 12:18 PM
    August425
    Auggie
    Yes. I swapped coils still misfired. Compression test resulted in 85 PSI which is low. Should be around 120 I believe. Checking the valves when I have time this weekend for leakage, valve alignment, etc. Also no damage to the spark plug as far as signs of burning or moisture.
