Cylinder 3 misfire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinkiger16, Feb 16, 2020.
  1. Feb 16, 2020 at 8:41 PM
    Kevinkiger16
    Kevinkiger16 [OP] Active Member
    Kevin
    2007 tacoma 2.7 manual
    Hello recently had cylinder 3 misfire I changed the plug and tried to swap the coil pack from cylinder 1 that was working to cylinder 3 to see if it was the coil pack still nothing. Code reader reads misfire in cylinder 3 bunch of ignition codes and bad crankshaft sensor? Any help would be much appreciated truck still starts but only for a little while before check engine light starts flashing then have no power
  2. Feb 16, 2020 at 8:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Any way you could post all the codes you are throwing?
    It might help narrow down the possibilities.
  3. Feb 16, 2020 at 9:09 PM
    Kevinkiger16
    Kevin
    Yeah I will when I can truck is gonna be towed to my house tomorrow hopefully I’ll be able to after work
    TnShooter likes this.
  4. Feb 16, 2020 at 9:23 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    My friends one did that, turned out to be head gasket. Water was getting into cylinder
  5. Feb 19, 2020 at 8:47 PM
    Kevinkiger16
    Kevin
    So I replaced the crankshaft sensor with a brand new one also replaced the spark plug and coil pack cylinder 3 is still misfiring. Any suggestions code reader is throwing code for ignition coil and crankshaft sensor still which I just replaced both brand new parts
  6. Feb 19, 2020 at 8:58 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Put a camera in cylinder 3. Then put the camera in another cylinder. Compare them. If you see obvious puddle of coolant in 3, it's head gasket. If 3 looks like it's been steam cleaned compared to build up on other cylinder, it's head gasket.
  7. Feb 19, 2020 at 9:01 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    But, head gasket failure is rare on a 2007, especially on cylinder 3. So don't get freaked out yet. Cam is easy cheap way to start diagnosis.
  8. Feb 19, 2020 at 9:10 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Valve cover and especially the spark plug tube gaskets along with a new coil and plugs fixed my misfire problem
  9. Feb 19, 2020 at 9:47 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Rrrrrrr....
    My bad OP, I just noticed you had a 2.7, 1GR-FE is my playground, never touched a 2.7. So I'll hand this one over to the 2.7 guys. But scoping cylinders can still help spot a bad head gasket.
  10. Feb 23, 2020 at 12:10 PM
    Kevinkiger16
    Kevin
    Still haven’t found anything only codes are ignition codes misfire in cylinder 3 and crankshaft sensor but I replaced that with brand new parts next thing to do is compression test
  11. Feb 23, 2020 at 12:14 PM
    Bishop84
    Bishop84 Well-Known Member
    Headgaskets often don't show up on compression test. So even if you get 170 across the board it doesn't rule it out.
    Usually headgaskets we check for fluid entering the cylinder with a camera after it sits. Sometimes you can see the symptoms on the spark plug of the cylinder. Last we use a leakdown test.
    I would swap injectors next if I were doing this at home.
    Compression test doesn't hurt and can show things like a broken valve spring, which is rare on those models.
    Taco 422 and TnShooter like this.
