Cylinder #4 Misfire, Coolant Leak/ Head Gasket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beeftaco05, Aug 13, 2015.
  1. Aug 13, 2015 at 2:40 PM
    beeftaco05
    beeftaco05 [OP] Well-Known Member
    Arizona
    05 TRD Sport
    I took my 2005 Tacoma 4.0 V6 (154k miles) into the shop for a major tune up. The work they completed was:
    -Replaced all air filters, and new spark plugs
    -Change the oil, lube driveline, and serviced rear diff.
    - Replaced upper hose, lower hose, and radiator cap. Plus flushed cooling system.
    - Transmission flushed
    A day after this work was completed the check engine light came on signaling a cylinder #4 misfire. I took it back to them and they said a spark plug was bad and replaced it. Around 2-3 days after, the check engine light came on again for the same thing (cylinder #4 misfire). I called them today and they said it could be the head gasket leaking into the cylinder.
    I bought this truck about a month ago, and this problem only started happening after this work was done. Is there any way they could have messed something up or is it just a coincidence?
  2. Aug 13, 2015 at 2:42 PM
    MPW
    MPW Member
    Mark
    Virginia
    I hate to hijack your thread, but when the CEL code is "miss in cylinder 4" is it actually cylinder 4 or is it the 4th cylinder in the firing order?
  3. Aug 13, 2015 at 2:44 PM
    beeftaco05
    Arizona
    05 TRD Sport
    Sorry, I'm not sure. I do not have the CEL code on me.
  4. Aug 13, 2015 at 3:32 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    When I had a misfire in #6 I replaced the coil on that cylinder. #6 as in the physical location per the Haynes manual. No problems since and that was over 150,000 km ago.
    Can you feel the miss? Rough idle?
  5. Aug 13, 2015 at 3:33 PM
    balljoint
    Dave
    Ontario
    '18 DCLB
    A cheap check to see if it's the coil would be to swap the coils from 4 and 6 and wait.
  6. Aug 13, 2015 at 3:39 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Unfortunately likely the HG, went through this myself last fall, common on the 04/5 V6 4R and tacos, usually around 160k. Any wooshing sounds in the dash, eating coolant? Swap the packs as suggested, if it stays on the same cyllider, likely the HG. You can check my build for more details and DIY costs.
  7. Aug 13, 2015 at 4:34 PM
    beeftaco05
    Arizona
    05 TRD Sport
    When I start up the idle is pretty rough at first.
    Yes, I do hear some wooshing sounds in the dash...
  8. Aug 13, 2015 at 6:32 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I would be pretty confident it's the HG then. If you are mechanically inclined, not a terribly difficult job, just time consuming, ~$800 all in.
  9. Aug 13, 2015 at 6:37 PM
    beeftaco05
    Arizona
    05 TRD Sport
    I figured... What a nightmare. Will know for sure tomorrow.
    I do not trust myself enough to do it. Thanks for the help though.
  10. Aug 13, 2015 at 6:40 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    No problem, try swapping the packs, then check for coolant disappearing. Those will pretty much nail it down. 3-4k at the dealer :eek:
  11. Aug 13, 2015 at 6:47 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    We just had a 4Runner V6 in the shop here with the same symptoms, I'm curious what it was about those models and years specifically that caused that failure.
  12. Aug 13, 2015 at 7:04 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    All signs point to a manufacturing issue, the part number changed in 2006 I believe. Much more common in the 4R than tacos for some reason, maybe has to do with Japan vs (US or Mexico for the tacos right?) manufacturing.
  13. Aug 13, 2015 at 7:27 PM
    beeftaco05
    Arizona
    05 TRD Sport
    Does anyone know if this slowly develops overtime, or just abruptly? The check engine light came on a day after I got it serviced, and less than a week of owning the truck.
    Do you think the previous owner knew about this? Could the mechanic have messed something up to cause this?
  14. Aug 13, 2015 at 7:32 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Mine was eating coolant for a month or so, and then noticed the dash noises. Finally threw the CEL. I don't see how the service could cause it, unfortunately likely just bad timing if it is the HG.
    It is possible it had the codes and they were cleared, mine came back pretty frequently though and would have shown pretty quick.
  15. Aug 13, 2015 at 9:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This could be what pushed it over the edge. I have seen more than one engine that doesn't have a head gasket issue and the owner decides to Flush the coolant system. Then boom cylinder full of coolant the next day or so. My son had this issue for the same reason in his old MR2. Actually had coolant running out the exhaust pipe and hydrolocked.
    Nothing that you could blame the shop for, not saying you have a blown head gasket. But it is a possibility.
    I would do as others suggested swap coil packs and if it remains on cylinder 4 get it checked for the head gasket.
  16. Aug 13, 2015 at 9:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :facepalm:
  17. Aug 13, 2015 at 9:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Start looking for another motor... just in case. [​IMG]
  18. Aug 14, 2015 at 5:46 PM
    beeftaco05
    Arizona
    05 TRD Sport
    It's a blown head gasket. $1,600 to fix. :(
  19. Aug 14, 2015 at 5:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You can do it more cheaply if you have the tools and instructions.
  20. Aug 14, 2015 at 5:49 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    And have a foampile experiance too.
    DoorDing, CurtB and Torspd[QUOTED] like this.
