Cylinder #4 misfire!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MapleMoose, Oct 28, 2011.
  1. Oct 28, 2011 at 2:36 PM
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    So my truck started shuddering when i started it up after lunch. It was fine on the way to lunch but now its not firing right. I got up to speed and the Cel started flashing which means the cylinder isn't working at all. Crawled my way back to work and scanned it... P0304 code cylinder 4 misfire.
    Now i need to get home today and the shop won't be.able to look at it till next week. Can i drive it or do i.risk snapping a rod??
  2. Oct 28, 2011 at 3:30 PM
    RIO5.0
    RIO5.0 Active Member
    99 Taco
    Generally thats a fouled plug...grab a new plug and change it out. Its just gonna run like ass...I wouldnt think you'd snap a rod. If a plug dont cure it, it might be a coil??
    Plug is a 2.00 fix... youll be able to tell instantly if she's fixed.
  3. Oct 28, 2011 at 5:16 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    my brother has a '02 4cyl. that developed the same symptoms. he keep on driving it while trying to diagnose the problems. the misfire would jump from cyl. 1 to 4 randomly and the engine shaking got worse over time.
    at the time the motor had like 245k miles so our last assumption was that it had a burnt valve. finally he had a mechanic friend look at it and he came to the same conclusion. at this point, instead of just replacing the valve, my brother decided to just rebuild the motor so the heads went off to the machine shop.
    it purrs like a kitten now and it seems to have more pep. hopefully, your situation isn't like his. you can start with replacing the plugs. swap the coils around and see if the misfiring moves to another cyl.
  4. Oct 28, 2011 at 5:17 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Changed plug 4 and it sounds better already.
  5. Oct 28, 2011 at 5:55 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Drove it and its still rough. Cel came back on and started flashing again. Code still reads cylinder 4 misfire... fuck!!!!
  6. Oct 28, 2011 at 9:15 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    plug wires? did the plug look fouled when you replaced it?
  7. Oct 28, 2011 at 9:23 PM
    ICEMAN
    ICEMAN Well-Known Member
    Eric
    Middleburg, FL
    2010 TRD Sport DC Silver 4x4
    Weather tech floormats K&N CAI fabtech 6" lift procomp 17x9 6079 Nitto Terra grapplers N Fab Nerf bars Nfab Light Bar Hella 500 FF
    it is your ignition coil for that cylinder. i had this same problem replace the coil yourself and save alot of $$$
  8. Oct 28, 2011 at 9:47 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    If it is misfires too long, you'll burn a valve and bend it.
    and lose compression
    old motor read like
    168-49-169-168
    :anonymous:
    Easy check is swap coilpacks around, clear code, drive it.
    Scan codes, if it jumps a cylinder, it's 100% a coilpack.
    Also, look into flowing your injectors..mine old 2RZ was missing because of coilpack plus also injectors weren't flowing correctly...there like $15-30 each to have them rebuilt with new baskets, o-rings and flowed.
  9. Oct 28, 2011 at 10:03 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thanks guys. Anyone have a write up for replacing the coils?
  10. Oct 28, 2011 at 10:18 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    unbolt, rebolt.
  11. Oct 28, 2011 at 10:44 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I've never done coils. Where are they
  12. Oct 28, 2011 at 11:01 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    LOL, if you can do spark plugs, swapping coils is cake. it should looks similar to this pic. unplug the harness and swap 4 to 1 and 1 to 4. reset everything and drive it around and scan for codes when the light comes back on. if it misfires in cyl.1 then its the coil, but if it still misfires in cyl.4 then you can rule out the coil.
  13. Oct 29, 2011 at 2:03 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Ok, so when you say swap 4 to 1 and 1 to 4, you mean you take out the coil and put it in the other and vice versa? Also i thought 3 coils were on the left of the engine and 3 plugs were on the right of the engine?
    5 6
    3 4
    1 2
    Front
    So how do i swap 1 to 4 if #4 doesnt have a coil?? Or am i swapping the wires?
  14. Oct 29, 2011 at 3:07 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    He was referring to a 4 cylinder, the 4 cylinders have coilpacks..1 coilpack runs 2 cylinders.
    You have individual coil's.
    Take 4 and put it where 3 is on opposite bank.
    Clear code, drive, when code pops back up..scan it..see if it says bank 1 cylinder 3 or whatever
  15. Oct 29, 2011 at 3:27 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    So basically swap 3 and 4, but leave the plugs in?
  16. Oct 29, 2011 at 3:29 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    yeah lol..your testing the coils..it has nothing to do with the plugs.
    Just make sure your plugs are gapped and within normal condition of plugs(not fouled, etc)
  17. Oct 29, 2011 at 3:46 PM
    millerm20
    millerm20 Member
    mark miller
    charlotte NC
    08 sr5
    if the light is flashing that means you could do harm to the catalytic converter from raw gas being feed to it
  18. Oct 29, 2011 at 3:51 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    True..but it will take ALOT..I drove on a misfire for a LONG time..because mine stumped me..I tried so many different things..then I finally checked compression and took valve cover off..and realized why.
    Mine still passed smog though after I fixed it.
    So it can ruin cat but it's gonna be dumping ALOT of fuel and for a long period of time.
  19. Oct 29, 2011 at 4:00 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Okay, so before i go ahead and start pulling things off and swapping them i need to be %100 clear of what im doing. Couple things dont quite make sense:
    1. If im swapping #3 coil into #4 hole and vice versa, how does it get power if the harness is unplugged?
    2. #4 plug gets power from #1 coil, so wouldnt it be easier if i just swapped #2 and #3 plugs?
  20. Oct 29, 2011 at 4:03 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    i don't know much about 5VZs..my bad. didn't notice how it was setup..so it's the same idea as 1-4, 2-3 on the 4 cylinders..i apologize for confusion
    just swap cylinder 4 coil to any other coil that is a seperate circuit, that's all you needa know..then clear the code.
