cylinder 5 low compression
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jacobseter, Dec 21, 2019.
  1. Dec 21, 2019 at 4:29 PM
    jacobseter
    jacobseter [OP] New Member
    jacob
    2007 toyota tacoma 4.0
    I recently purchased a 2007 toyota tacoma with 91,000 miles. It had all sorts of engine codes and runs rough. replaced spark plugs which were extremely worn. It helped the rough idle some. has a misfire in cylinder 5. tried the swap coils and plug (before i bought new plugs) have all new now. misfire never changed cylinders. put a compression tester on cylinder 5 was 90 psi checked cylinder 3 that was 140. removed valve cover and made sure intake valves were closed on cylinder 5 and hooked shop air to cylinder and have air coming out intake. I assume the valves are bad. Has anyone else had intake valve issues?
  2. Dec 21, 2019 at 4:35 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    No issues but, sounds like you need a valve job
