Cylinder 6 misfire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eastonK, Sep 16, 2019.
  1. Sep 16, 2019 at 6:34 AM
    eastonK
    eastonK [OP] New Member
    2005 Tacoma TRD Off-road
    I’m having issues with my 2005 Tacoma 4.0. I had engine shake at startup so I changed plugs. It was due anyway. Ran fine for 4 months. Filled the tank one day and came out the next time to start it and it was shaking and threw a cylinder 6 misfire code. Changed plug in cylinder 6 and it was good for 2 days then it threw the same code again. Changed plug again and this time I switched coil packs. Ran ok for day or two and yep you guessed it. Cylinder 6 misfire again. This time I got new plug and changed oil because it was due. Put a can of Seafoam in it and filled it with 93 octane. Ran for a day and threw code 306 again. I’m running out of ideas. Any suggestions would be great.
  2. Sep 16, 2019 at 7:00 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Who wants to say it? I'm not going to...
  3. Sep 16, 2019 at 7:02 AM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW :notsure:
    Or clean the maf and throttle body?
  4. Sep 16, 2019 at 7:11 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Run a compression test on all cylinders. It's likely cylinder 6 will show the issue. My guess is headgaskets
    How many miles on the truck
    Larzzzz, mojojojo78 and Torspd like this.
  5. Sep 16, 2019 at 7:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hmm. Blowing coolant or no?
    If no, swap that coil pack with another coil pack, and see if the misfire follows that coil pack.
    BassAckwards likes this.
  6. Sep 16, 2019 at 7:31 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Head gasket?
  7. Sep 16, 2019 at 8:20 AM
    Fullboogie
    Dave
    Houston
    I hate seeing these posts. Hard starting, misfiring that doesn't follow a swapped coil - kinda points to one thing. I hope it's not the case, though.
  8. Sep 16, 2019 at 8:34 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Patience grasshopper...
    At some point, there won’t be any ‘05s and early ‘06es left.
    Lester Lugnut and Torspd like this.
  9. Sep 16, 2019 at 1:26 PM
    eastonK
    The truck has 145,000 on it. Plug hasn’t been wet any of the times I swapped it. Head gasket is what I was thinking but not what I wanted to hear. $$$$$$
  10. Sep 16, 2019 at 1:57 PM
    BassAckwards
  11. Dec 4, 2020 at 11:37 AM
    msimons99
    msimons99 New Member
    Did you ever get the answer here?
  12. Dec 4, 2020 at 11:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Having a similar issue here?
  13. Dec 4, 2020 at 1:25 PM
    msimons99
    Yep - frustrating
  14. Dec 4, 2020 at 1:31 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    I almost bought an 06, yikes
    PzTank[QUOTED] likes this.
  15. Dec 4, 2020 at 2:24 PM
    PzTank
    Above the Notches
    Depends on the month.
    IIRC, November 2005 was the change over date to the improved version of the HG.
    Someone more knowledgeable should verify.
    Edit: quote below has my senior moment 2015 date....
  16. Dec 4, 2020 at 3:02 PM
    Fullboogie
    Dave
    Houston
    You are right. I've bought two '06's in the last two years and made sure both were well beyond that build date.
  17. Dec 4, 2020 at 3:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Checked for continual bubbling in your overflow tank? More so when mashing the skinny pedal?
    Checked for hydrocarbons in the coolant system?
  18. Dec 4, 2020 at 3:51 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    If by some miracle HG is OK, could the problem be due to bad #6 injector?
  19. Dec 4, 2020 at 4:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could be that as well.
  20. Dec 5, 2020 at 9:32 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    You should have bought a 4 cyl..... you wouldn't (couldn't) have this problem
