Cylinder misfire help
Discussion in 'General Tacoma Talk' started by Skawdyb, Aug 13, 2024.
  1. Aug 13, 2024 at 10:07 AM
    Skawdyb
    Skawdyb [OP] New Member
    2011 Tacoma trd off-road
    Hey all, I have a 2011 tacoma 4.0 w/ 120k miles with a cylinder 2 misfire that I’m trying to diagnose. Hoping to get some opinions before I get into the fuel lines or compression test.
    -Replaced plugs for routine about 3 months ago
    -about 1000miles later it started to run rough while under load and have a cyl 6 misfire, swapped coil w/ cyl 2 and no luck, changed out the plug and it fixed the issue
    - about 500miles later cyl 2 did the same thing, put a new plug and a new coil in on cyl 2 and still having same issue, starts to buck then loses firing on cylinder 2 when I accelerate.
    Any insight will help, thanks.
  2. Aug 14, 2024 at 7:00 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Could be a head gasket issue, coolant leaking into the cylinder causing the plug to foul up. I would do a chemical block test to see if there is any exhaust gases in the coolant system. Had this happen on an old ford ranger before.
    wilcam47 likes this.
  3. Aug 14, 2024 at 7:44 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    how does the wiring connector going to the #2 cylinder coil look? have you tried swapping that coil with another to see if the problem moves?
    and how did the plug look? if anything is happening like coolant entering, it should be evident on the plug.
    also, what plugs did you use?
  4. Aug 15, 2024 at 4:27 PM
    Skawdyb
    Yeah I tried swapping coils, tried a few different times with different cylinders since that’s the easiest. Coil wires appear to be in good shape. No lose of coolant or visible damage to plugs, also replaced plug with new one and same issue occurred. Used the Denso K20HR-U11 copper plugs
    soundman98 likes this.
  5. Aug 15, 2024 at 4:34 PM
    JFriday1
    Jesse
    Lakewood, CO
  6. Aug 15, 2024 at 4:38 PM
    cfarley
    cfarley Well-Known Member
    Michigan
    2023 TRD Off-Road
    Center console organizer
    Not that this is you issue but clogged cats can produce misfires that don't move cylinders and lack of power up top. The only way you'd know is to take them off though. Maybe it could be an injector or possibly wiring
    str8upoutdoors likes this.
  7. Aug 15, 2024 at 4:38 PM
    GearHead899
    GearHead899 Well-Known Member
    Justin
    Ocean View, NJ
    11' Black X-Runner, 06' RR X-Runner
    Do you have a bore scope or compression checker by chance?
