Cylinder3 misfire. 20% loss of compression. What now?
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Jun 15, 2012.
  1. Jun 15, 2012 at 7:37 AM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    My engine (2.7) has been shaking like crazy for a while. It is really only noticeable when I am at a stop. I replaced the plugs and wired thinking that was the problem but it did not help.
    I recently had a P0303 code (cylinder #3 misfire) pop up and I thought that might be an indication of what was wrong with the engine so I took it to my mechanic to see if they could tell what the problem was.
    The mechanic indicated that I only had 80% compression on cylinder #3. What do I do now? The mechanic did not really offer any suggestions, he just diagnosed the problem (which I guess is all that I asked him to do).
    Do I need to budget for replacing the entire cylinder head?
    If I need a new cylinder head, does the cylinder head come already assembled ready to bolt on or are there other parts needed?
    Where is a good place to purchase one (if I actually need one)?
  2. Jun 15, 2012 at 10:20 AM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    How much oil are you burning in an oil change? Is it significant? Have you noticed a change since the motor started shaking?
  3. Jun 15, 2012 at 11:14 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Do a compression check, and if one cylinder has low compression put some oil in it and measure again. That's how you check the rings. Otherwise it may be a valve.
  4. Jun 15, 2012 at 11:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    The compression should be between 127- 178 psi but the differential between cylinders should only be 14 psi or less.
    As koco said, do it again with oil in the cylinder. If it stays low it's a valve seat or possibly the head gasket.
    You don't need to replace the head. As long as it checks out good, you can have the valves redone or replaced, which ever is necessary.
  5. Jun 15, 2012 at 11:29 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    did the mechanic test all 4 cylinders?
  6. Jun 15, 2012 at 2:02 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    I am not sure if the mechanic tested all four cylinders. I would assume that he only tested one since the code was referencing only one cylinder. He referenced a 20% leakage on cylinder #3 on the printout he gave me so I assume he only did one cylinder. I will check and see if I can have all four cylinders tested for comparison.
  7. Jun 15, 2012 at 4:09 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
  8. Jun 15, 2012 at 4:22 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    testing only one cylinder is pretty pointless. It's the difference in pressure between cylinders that matters most unless you have like 100 PSI across the board.
  9. Jun 15, 2012 at 4:35 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    I think I am going to purchase (or rent) a compression tester and check it out myself this weekend. I am going to do a dry and a wet test to see what totals I come up with and will report back once I have some more data.
  10. Jun 15, 2012 at 5:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    hold the throttle wide open during cranking.
  11. Aug 13, 2012 at 4:14 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    Ok I finally did a wet and dry compression test. The figures did not make any sense to me. Can anyone help me make sense of these figures.
    Cylinder #1: Dry: 200, Wet: 270
    Cylinder #2: Dry: 170, Wet: 220
    Cylinder #3: Dry: 185, Wet: 240
    Cylinder #4: Dry: 190, Wet: 210
    Does these figures make any sense?????
  12. Aug 13, 2012 at 4:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Not horrible but not good either. Cylinder 2 being 30 PSI lower than the highest is a bad sign. Next step would be a leakdown test on that cylinder to see if it's the rings or the valves.
  13. Aug 13, 2012 at 6:15 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    What gets me is that my vehicle is throwing a P0303 code which is a cylinder #3 misfire. The cylinder #3 seems to be ok while cylinder #2 seems to have the lowest compression.
  14. Aug 13, 2012 at 8:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    cylinder 3 is not okay, it is too low in comparison to cyl 1. It is weird that it doesn't throw a code for cyl 2 though. Hopefully someone with more knowledge than I will chime in.
  15. Aug 13, 2012 at 10:46 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    my brother has an '02 2.7L and went through a similar issue about a year ago. it turned out to be a burnt valve.
