Cynicalriders "J0hnny5 is ALIVE!" 01 build thread.
Discussion in '1st Gen. Builds (1995-2004)' started by cynicalrider, Aug 8, 2013.
  1. Feb 13, 2023 at 5:06 PM
    #2361
    cynicalrider
    cynicalrider [OP] #NFG
    Jersey
    Oof. Haven’t experienced it blowing out in use yet afaik. What did you tell them when you sent it in for warranty? And how much did it run?
  2. Feb 13, 2023 at 8:26 PM
    #2362
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Fortunately mine is still under warranty since they built it for me back in 2020. So free.99
    But the invoice said 750 for the diff build labor irrc. And then I don't remember what the part costed.
    I wasn't experiencing it blowing out during use originally either, only on long drives for whatever reason. It had some pretty weird behavior as to when it would do it. But then one day when I went snow wheeling and was using it, I heard it gurgling pushing out fluid when I got out of the truck to do some winching while it was still locked up.
    If I were you, I would keep a close eye on the breather to try and pinpoint when it's exactly happening. Kinda hard though as that area gets all oily and sucks to cleanup. I was getting real tired of the left side of my engine bay getting covered in gear oil.
  3. Feb 14, 2023 at 3:39 AM
    #2363
    cynicalrider
    Jersey
    yeah I’ll def keep an eye on it for sure. Had this in since May of 2017 so def out of warranty now. Though it’s lasted longer than all my other friends arb’s. Did it ever stop locking up?
  4. Feb 14, 2023 at 5:43 AM
    #2364
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That video is a great find. Was having the same issue until I found that, easy troubleshooting with the paper clip confirmed it was the switch. Been fine for 2 years since
  5. Feb 14, 2023 at 6:18 AM
    #2365
    cynicalrider
    Jersey
    Did you replace the switch or use the remove switch and fuck with it/clean it a bunch and reinstall method?
  6. Feb 14, 2023 at 6:30 AM
    #2366
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Just replaced it since I found a cheaper one on Amazon I think. It kept pissing me off with the lights not working so I just swapped it for piece of mind
  7. Feb 14, 2023 at 8:33 AM
    #2367
    betterbuckleup
    Ian
    Concord, CA
    It's still locked up, but I'm sure it would eventually stop if I let it keep going
  8. Feb 14, 2023 at 1:23 PM
    #2368
    cynicalrider
    Jersey
    Bringing this list up to start crossing shit off and making sure I don't forget anything.
    Starting at the motor:
    Replacing valve cover gaskets, half moons, and cam seals, and plug seals.
    Replacing injectors
    Replacing FPR
    Replacing fuel line under the plenum
    Replacing the coolant hoses under the plenum
    Replacing 3 coils and new wires
    Replacing the spark plugs
    Replacing pcv valve
    Replacing all vacuum lines with the silicone kit I have had for 3+ years now
    Clean MAF
    Clean throttle body
    Clean plenums
    Change oil
    Outside of that at the motor:
    Replacing the AC idler AGAIN. Got an OEM unit this time.
    Bang and smash the skids for reinstallation. (Going to start planning my tube skid concept too)
    Swap the fluid in the front diff with all the pines trips lately.
    Suspension:
    Grease UCA's and upper ball joint.
    Check tolerances at LBJ's
    Replace misalignments on the lower coilover mounts to push them further from the CV's
    Replace the drivers side CV with the boot that's been torn since Takeover in July.
    - Still need to get my passenger shock back from my buddy.
    Reboot and rebuild the removed CV.
    Misc:
    Figure out why the reverse lights have been intermittent. Going to start at the switch on the case since I just had that off when the transmission was out. Then check under the seat since I tapped into that for the reverse cam not to long ago.
    Rotate tires
    Touch up armor
    Touch up wheel paint
    Swap clutch spring and bushings
    Fluid film the frame after painting is done.
    Dang look at that progress.
    jubei and Justinogo like this.
  9. Feb 16, 2023 at 9:17 AM
    #2369
    cynicalrider
    Jersey
    MY50cal, Justinogo and jubei like this.
  10. Feb 18, 2023 at 7:24 PM
    #2370
    cynicalrider
    Jersey
    Bringing back the OG list:
    Not on the major list that I just want to write down so I can remember to do it:
    Wash truck
    Rotate tires
    Check suspension components for wear
    Bringing this list to the top to get my ass motivated again on cleaning the truck up for this year. A lot of the upcoming maintenance is dealing with rust/repainting shit.
    Get a back door stitched up to attach to current rack.
    Get tube cut and bent/welded to the back of the current rack.
    AC pulley
    Alright making this it's own post. I took a deep dive into the goals for the truck, and the things I want to improve. This list is always changing/ being improved upon, completed or added to.
    As always green was just completed, BOLD is priority/realistic. Anything previously green gets deleted (though I still need to update the build specs lol). Of course this is all for my sanity's sake.
    Maintenance:
    Armor up rear diff, fix plug, or weld plug permanently shut and replace two studs with bolts to drain
    Plugs
    Wires
    Paint rear bumper, drill holes out bigger to accept 3/4" shackles
    Rust convert and paint sliders
    Deal with rust spots on the cab under the doors
    Remove rust and touch up paint on rack - specifically in the hinge/latch area
    Swap doors so I can start on half doors
    • Passenger door needs to be swapped for spare door in better condition
    • Drivers door needs rust removed, painted and resealed with seam sealer - reference link
    • Donor drivers door needs tar cleaned off of it to start on half door build
    • Passenger door needs rust repair before being able to be used for half door build
    Paint black stripe on bottom part of body to address rust staining - this will help for the doors that have been repaired from rust
    Rebuild the spare alternator (need rebuild kit)
    Power steering rack, filter and system bleed
    New CV on Drivers side
    Get new misalignments for coilovers and rebuild bushing
    New OEM ac tensioner pulley
    Interior Mods:
    Recondition seats
    Platform in back with taller rear locking storage, a place Mac can be raised up on while the fridge stays at the same height)
    Lit up cup holders
    Tablet lighting solution using Raspberry Pi
    Switch reconfiguration
    Put in cubby under the fridge:
    Change of clothes, canned foods with long expirations, fire starter kit, emergency blanket, MRE's. Stuff that is worst case scenario survival shit.
    Exterior Storage Mods:
    Build a dual swing out tire carrier. The one swing out will contain the 35" tire, and a fold down table. The left side will hold the high lift and chain saw and will also have a fold down table. The goal is to make everything more accessible without needing to unload the truck. - Potentially decommissioning this idea.
    Figure out a ramp mount solution when hauling the bike. Maybe prinsu rack on cab?
    Potentially add a roof rack above the cab to hold traction pads/a plano case that contains recovery gear. The jury is still out on this concept. I would like to avoid adding anymore weight that high if I can. See ramp mount point. ^
    Performance upgrades:
    ABS controller delete/LSPV delete/manual valve install and complete fluid flush
    Dual battery setup, one battery in current location, the other under the bed. This will be the house battery that the fridge, and all lighting accessories will run on.
    Crawl box: I need lower gears to really take the truck to the next level crawling wise.
    Build/get built beefier drive shafts
    Custom Alcans or Deavers: Once I get the average weight of the rear figured out as a typical always on rolling weight, I want leaves to be able to hold the weight of my normal everyday load. Airbags will be the interim solution.
    Install Manual hub tube, replace the seal. Potentially pull the shaft, get heat/cryo treated.
    Lighting Mods:
    3 additional floods to rock lights (one facing from the rear bumper to the diff, and two near the front facing down near the bumpers, goal is to eliminate the current dead spots)
    Hood lights on pin switch
    Get lights for spindle mounts
    Mount and wire spindle lights
    Misc Exterior/ Camp Mods:
    Redline Hood struts
    Heat exchanger in engine bay for warm showers
    Fiberglass fenders and bedsides (this will eliminate some of the body glamage I have gathered over the years)
    Half doors
    New bedside decals
    Print up decals of trails from Moab, put on cab
    Window tint - need new windshield
    Far future plans:
    LT or 3-link
    Bike mod list currently:
    Taco moto fork blinkers
    sicass clear flush mounts
    sicass turn signal indicator kit
    sicass smart flasher
    wireless charger
    tap for power source
    mirror
    fork pouch
    suspension tune
    It's weird seeing the list actually get shorter. Repainting stuff is my next priority. Taking it for a rip to the pines Monday, then cleaning and working on touching that shit up.
    Oh now that the tires are rotated I should prob get an alignment too.
    Even though the crawlbox is ordered it's low on the priority list for this year. I'd like to prioritize true dry storage in the bed with the rack cover getting restitched/door added so I think that will be the next important part.
    for memory - poly body mounts and splash guards
    Bandido likes this.
  11. Apr 1, 2023 at 7:18 PM
    #2371
    cynicalrider
    Jersey
    Been a minute but I actually used the truck and did some shit.
    Went camping so I could go riding the next day. Was a foggy/rainy night that really showed all my lighting.
    [​IMG]Untitled by Michael Halat, on Flickr
    Woke up to 180* views of the mountain:
    Use my Mr. Buddy with fan to get comfy at night. First time in the tent and it was awesome.
    Way better than the heater alone.
    Explored the forest a bit and found some views and a fire tower:
    The load out for brap camping is pretty legit.
    Easily doable for a trip to Moab, one day hopefully in the future.
    Also installed geartech customs splash guards, the hope is keep grime off the motor after all the work I did.
  12. Apr 3, 2023 at 2:05 PM
    #2372
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    What area did ya hit up?
  13. Apr 4, 2023 at 2:55 AM
    #2373
    cynicalrider
    Jersey
    to ride or camp? We rode FRO at the Burns tract and I camped in Port Clinton PA. FRO some super awesome riding.
    slander[QUOTED] likes this.
  14. Apr 18, 2023 at 7:21 AM
    #2374
    cynicalrider
    Jersey
  15. Jun 25, 2023 at 4:43 AM
    #2375
    cynicalrider
    Jersey
    Damn I haven't posted in here since April?
    Been riding a ton, trying to get my body ready for the Quarry Run up in Hancock in August.
    Been getting my son out with me whenever I can.
    I can't wait till we can truly ride together when he gets bigger.
    I took him camping for the first time with @JLink
    He loved it and did awesome.
    Did a bday camp and ride with @HuneyBear69 and @Chux
    Did Durty Dabbers again with @HuneyBear69
    Got out for Father's Day with the fam:
    And lastly got out in North Jersey with @Yota X
    This was the first time I took him in the rocks and he actually loved it. I think I can easily do a trip with him to an offroad park now. Something I have been excited about for a long time.
    The truck has been doing everything I ask it to. Seems like all the valve cover stuff I did is holding up and the motor is running strong. I do need to really beat on it wheeling soon but it's been functioning great as my mobile base camp for riding trips. For family stuff though, it's just not sustainable. To have both my wife and son in the truck + the dog the fridge needs to come out. And it's not comfortable for any of them. Usually though it will always only be Mac, my son and I for camping/wheeling so it works for now.
  16. Jun 26, 2023 at 1:51 PM
    #2376
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    lol. Awesome pics of jr on the bikes! I saw some of the pines ones but not the truck stuff. That 100 series looks nice!
    cynicalrider[OP] likes this.
  17. Jul 15, 2023 at 5:02 AM
    #2377
    cynicalrider
    Jersey
    Build catch up, not much building happening.
    This came fully out of the box:
    Did camping with @HuneyBear69 in the pines with the kiddo.
    Then camped with @JLink, his wife and their daughter up in NY.
    Got some awesome solo riding in.
    Said goodbye to the corolla.
    [​IMG]IMG_6644 by Michael Halat, on Flickr
    [​IMG]IMG_6635 by Michael Halat, on Flickr
    And bought a minivan.
    Specs are 2023 Bronco Wildtrak. Wildtraks come standard with the "Sasquatch Package" which has F/R Lockers, 4.70 gears, 35's and the Wildtraks come with factory tuned Fox 2.5" IBP's and the same severe duty steering rack the Braptor comes with, and heavier duty tierods. Added features were dual tops, full skids (but doesn't cover the transmission :rolleyes:), the modular front bumper, tow, and roof rack.
    And no, the Tacoma is NOT going away. This is now my DD/family camp/roadtrip vehicle.
  18. Jul 21, 2023 at 12:43 PM
    #2378
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  19. Jul 25, 2023 at 7:36 PM
    #2379
    cynicalrider
    Jersey
    11 years with this truck. So many damn good memories.
  20. Jul 27, 2023 at 11:53 AM
    #2380
    JLink
    Josh
    Ocean, NJ
    I’ve had my truck 13 years now. Seems hard to believe.
