Cynicalriders "J0hnny5 is ALIVE!" 01 build thread.
Discussion in '1st Gen. Builds (1995-2004)' started by cynicalrider, Aug 8, 2013.
  1. Oct 27, 2023 at 10:25 AM
    #2401
    cynicalrider
    cynicalrider [OP] #NFG
    Jersey
  2. Nov 14, 2023 at 6:14 PM
    #2402
    cynicalrider
    Jersey
  3. Nov 15, 2023 at 12:12 PM
    #2403
    cynicalrider
    Jersey
    So I posted that last night because I was trying to download the gif but it's reality too. Nothing show stopping but annoying maintenance that needs to be done. Went to install the new Durobumps and realized that every nut inside the LCA besides 1 had it's spot welds snapped off. I thought the nut rode in like a slot but it looks like that's not the case. I got this one off by jamming a pickle fork under the bump to slowly get the bolt out.
    [​IMG]Untitled by Michael Halat, on Flickr
    So the current plan is to pull the coilovers, disconnect the LBJ's and just push the spindle out of the way to drill out the holes and weld a flange nut upside down into each spot. Easiest way to do it aside from completely removing the LCA's which I don't really want to do. Also saw I have slight play in both my LBJ's so I will likely replace those and the OTRE's again. What started as putting on some simple parts now went down the usual worm hole of maintenance catch up.
    :bananadead::bananadead::bananadead:
    On the bright side it reminded me of how freaking nice it is to have a capable brand new vehicle in the driveway that I can use for adventures in the meantime.
    slander, jubei and ToyRyd04 like this.
  4. Nov 15, 2023 at 12:13 PM
    #2404
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Fluid film, Krown, whatever your choice is make sure to get that nice new vehicle coated up before the snow flies, never this fresh again over on your side of the country.
    Dalandser likes this.
  5. Nov 15, 2023 at 12:43 PM
    #2405
    cynicalrider
    Jersey
    Absolutely. Actually trying out this stuff this year:
    https://www.amazon.com/Blaster-128-SS-Surface-Shield-1-Gal/dp/B09HGL5R58
  6. Nov 15, 2023 at 5:16 PM
    #2406
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    How many miles on those lbjs? Oem?
    Wonder how long a modern vehicle could put up with the abuse before needing attention.
  7. Nov 16, 2023 at 6:32 AM
    #2407
    cynicalrider
    Jersey
    Yeah OEM and it looks like they were last replaced when I put the ADS shocks on in 2019. Just checked mileage on the truck and I am at 260100 exactly. I estimate in 2019 I was somewhere in the range of 245k because I hit 250k on the way to MA/VT in 2021. So maybe 15k ish? They def don't last as long now that I can go a lot faster
    :burnrubber:
  8. Nov 16, 2023 at 9:07 AM
    #2408
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    You should consider a set of Solo LCA's
  9. Nov 16, 2023 at 9:14 AM
    #2409
    cynicalrider
    Jersey
    If I was going to spend that kind of money it would be for going towards long travel. TBH I don't need them. I considered going for the TC LBJ's but I don't want to get a set and then eventually replace them with the heim set.
  10. Nov 16, 2023 at 9:18 AM
    #2410
    betterbuckleup
    Ian
    Concord, CA
    Fair enough.
    Although with replacing the LCA's a couple times, you're prob not far off from the cost of them anyways. It's nice having the peace of mind that my LCA's are going to be the last thing to break in my front suspension
  11. Nov 16, 2023 at 9:21 AM
    #2411
    cynicalrider
    Jersey
    Are we talking LCA's or LBJ's lol The LBJ is what's worn, the LCA I have already beefed up with @eimkeith's gussets so it won't be breaking anytime soon. The bump bolts being busted inside the LCA is an easy enough fix, just takes time more than anything.
  12. Nov 16, 2023 at 10:04 AM
    #2412
    betterbuckleup
    Ian
    Concord, CA
    Ah ya forgot you had the eimkeith reinforcement stuff.
    I will say I've seen a few LCA's get bent backwards at the legs that connect to the frame pivots. But you would have to take quite a hit likely for that to happen
  13. Nov 16, 2023 at 10:24 PM
    #2413
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is the OEM bump in the forward position of the LCA or are you only running the duro bumps on the rear half?
  14. Nov 16, 2023 at 10:28 PM
    #2414
    Digiratus
    Roaming the PNW
    The RedHead
    And I love the Stone Brewing sign. Those guys make a mighty fine double IPA. One of my favorites.
    eimkeith and jubei like this.
  15. Nov 17, 2023 at 1:05 PM
    #2415
    cynicalrider
    Jersey
    Yeah I am running the OEM bump up front and the durobump in the rear. Curtis actually sent me different bumps for up front now too as well as our bumps he has for the rear so I will be having durobumps in both positions now.
    Dude Ruination was my go to daily beer. I hate that it was discontinued or only comes in random packs sometimes.
  16. Nov 17, 2023 at 2:01 PM
    #2416
    Digiratus
    Roaming the PNW
    The RedHead
    Our front suspensions are very similar. I was trying to figure why you picked up that damage to the bump mounting. I guess it isn't what I thought it was.
    My goto from Stone has been their Enjoy By for a number of years. They make it 3-4 times a year. I like the expire date as part of the name. Ruination is another from them that I like. Only see it once, maybe twice a year though. Have you seen Ruin10. Based on Ruination but it is a triple. At 10% it is amazingly smooth and dangerous. Again, only seen it once this year.
  17. Nov 19, 2023 at 4:06 AM
    #2417
    cynicalrider
    Jersey
    Ah word, yeah I think it may have just been abuse/age. I was one of his first batches ever made and I know he did alter the formula sometime after the original batch.
    And dude Ruin10 is a banger. Like you said dangerously good ha.
    surfishjoe likes this.
  18. Nov 19, 2023 at 4:13 AM
    #2418
    surfishjoe
    surfishjoe Well-Known Member
    Joe
    Margate, NJ
    2004 Double cab TRD
    Hey Mike the diff didn't break I think I finally replaced all the damaged parts- thanks again for the helping out.
  19. Nov 19, 2023 at 9:48 PM
    #2419
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    That's the truck telling you that it wants a SAS
  20. Nov 20, 2023 at 10:27 AM
    #2420
    cynicalrider
    Jersey
    :thumbsup:
    ain’t nobody got time fo dat. I barely have time to use it let alone sas it :p
