Cynicalriders "J0hnny5 is ALIVE!" 01 build thread.
Discussion in '1st Gen. Builds (1995-2004)' started by cynicalrider, Aug 8, 2013.
  1. Feb 28, 2025 at 7:48 PM
    #2461
    cynicalrider
    cynicalrider [OP] #NFG
    Jersey
    Truck finally rolled out of the garage under it's own power right before vacation.
    The majority of the time was getting this how I wanted it to be.
    [​IMG]Untitled by MJH Creations, on Flickr
    I took the plasma, cut two pieces of 1/8" and wrapped them around the drain hole bump. I fully welded it all and then ground it all flush.
    Now I have no leaks and a smooth and thicker bottom.
    I also wasted time on this to make a dumb joke on the internet about having a Temu Diamond axle... worth it.
    I also got the passenger side bearing in and backing plate assembled, glad I keep my makeshift tools from other times I have done the job.
    Swapped all the shit to the new tank:
    I also used this opportunity to freshen up a bunch of stuff with PC.
    Gas tank skid, jerry can carrier, e locker guard and exhaust bezel all got done.
    Brakes got all new hardware, adjusters, drums, shoes and wheel cylinders.
    Final results all assembled:
    So new parts/mods are:
    New gas tank
    Powdercoated gas tank skid
    Powdercoated elocker guard
    Powdercoated jerry can carriers and added rubber for tighter fit/less wear
    Powdercoated tailpipe, bezel and adjusted the exhaust to have more poke
    Skinned and sealed the bottom of the diff
    TG stud elim kit
    2 bolts added for drainage
    Fresh diff fluid
    Rear, both sides - Drums, shoes, wheel cylinders, spring hardware, star adjusters, and adjuster levers.
    Rear passenger only - Wheel bearing, axle studs, backing plate, and dust seal.
    I have a smaller list of minor projects/fixes/cleanup I have ahead of me that I'll write out another night to have it somewhere else besides my notes app.
    turbodb, Cascadesubtaco, CoWj and 8 others like this.
  2. Jul 2, 2025 at 7:59 AM
    #2462
    cynicalrider
    Jersey
    It's been a minute since I have updated this thread. Truck has been performing well with no major issues. Got shit news in March that my son was diagnosed with Leukemia so most of life has been spent navigating that. We have been doing the best we can to get him out camping and enjoying life to the fullest though. Photo dumps:
    Wheeling with @Yota X
    Snapped a CV on a climb I have done with no issues twice before but apparently was slick af in the spring.
    It made me feel better that @Rockbaron1 had to winch too:
    Also camped and wheeled with @Chux at AOAA.
    [​IMG]IMG_3377 by MJH Creations, on Flickr
    [​IMG]IMG_3408 by MJH Creations, on Flickr
    [​IMG]IMG_3383 by MJH Creations, on Flickr
    [​IMG]IMG_3387 by MJH Creations, on Flickr
    [​IMG]IMG_3388 by MJH Creations, on Flickr
    cbechtold, jubei and Bandido like this.
  3. Jul 2, 2025 at 8:09 AM
    #2463
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    damn dude. im sorry you and your family are going through that. cant imagine what that would be like as a parent.
    wish all the best going forward
  4. Jul 2, 2025 at 8:20 AM
    #2464
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    Man that is heartbreaking. You don't know me but I've been following this thread for a while now. You have a good little man there. Wishing you the best in his treatment.
  5. Jul 2, 2025 at 8:40 AM
    #2465
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Man that is tough news to hear. If you end up down here for St. Jude at any point, feel free to reach out if you need anything
  6. Jul 2, 2025 at 2:37 PM
    #2466
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Good stuff Mike. Hang in there and get that kiddo feeling better!
    Speedytech7 and jubei like this.
  7. Jul 3, 2025 at 5:50 AM
    #2467
    cynicalrider
    Jersey
    I really appreciate all the kind words everyone. He is a strong little dude and CHOP has been amazing, literally one of the best in the country for this so we are thankful to be close to it.
    Speedytech7, jubei and turbodb like this.
  8. Jul 3, 2025 at 7:51 AM
    #2468
    cynicalrider
    Jersey
    Actual build things did happen though, the STT Pro's are mounted and flex nicely.
    And I finally installed my Cascadia 4x4 VSS setup, and built a quick bracket to mount it over the charcoal canister.
    I converted my gravity fed jerry can to a new system called H2GO that uses a 12v plug to power the pump in the can. It's nice not needing to pressurize the can and I am working on creating a faster setup time for it too.
    I did the ball chiller mod using a used 4runner duct and a new vent from toyota.
    Some garage mods, I got a free shelf form a neighbor so I then got a 3/4" plywood sheet and cut it up and painted it to organize the garage better. The biggest thing is to get the t cases/diffs and other heavy things off the ground. Garage organization is still in progress though since I am in the middle of the Bronco Broverland build too.
    I also fixed the light in this sign that I bought years ago and failed.
    Overall solid progress. Once the Bronco is put back together I am probably going to try to focus on further garage organization, and trying to commit to getting the Tacoma windshield replaced, tint done, better fridge and pump wiring, and maybe trying to finally finish the bed rack to get the cover on. That or finally install the NWF case and 5th gear swap parts that have been sitting collecting dust for 2 years.
  9. Jul 3, 2025 at 7:59 AM
    #2469
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i was so glad to be off the STT pros as they were wearing out. they got very loud on the highway and wouldnt wear evenly on the lugs without frequent rotations. just fyi
  10. Jul 3, 2025 at 8:58 AM
    #2470
    cynicalrider
    Jersey
    Ha yeah it seems to be a weird Cooper thing, my MT Maxx's got the same towards the end. Thankfully my tires last a while on this truck since it's not my daily, My ST Maxx's got installed in 2016 and still had a little life left. Maybe by year 5 I will finally have installed sound deadening in the truck :p
    jubei likes this.
  11. Jul 13, 2025 at 9:19 AM
    #2471
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I used a window washer pump to pump water from my Jerry can. It's been working great! Nice to be able to stash the can somewhere out of the way and just have the hose and switch handy.
