Cynicalriders "J0hnny5 is ALIVE!" 01 build thread.
Discussion in '1st Gen. Builds (1995-2004)' started by cynicalrider, Aug 8, 2013.
  1. Apr 12, 2017 at 1:18 PM
    #621
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Robmonster117 and jubei like this.
  2. Apr 12, 2017 at 1:19 PM
    #622
    cynicalrider
    cynicalrider [OP] #NFG
    Jersey
    I was thinking that but he's coming from Cali! So going backwards. :annoyed::pout:
    Edit: For at least the kokopelli out to RT.
  3. Apr 12, 2017 at 1:21 PM
    #623
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Meh I think the kokopelli trailhead is only an hour and a half past moab on 70.
    jubei likes this.
  4. Apr 12, 2017 at 1:23 PM
    #624
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Great point.
    I think it's be awesome to have you along, Rob!
    Robmonster117 likes this.
  5. Apr 12, 2017 at 1:27 PM
    #625
    cynicalrider
    Jersey
    Yeah if that's the case, you're required to join @Robmonster117 :p
    jubei[QUOTED] and Robmonster117 like this.
  6. Apr 12, 2017 at 1:28 PM
    #626
    Reh5108
    Idaho
    I'm gonna be the only one on 33s :tumbleweed:
    jubei and Robmonster117 like this.
  7. Apr 12, 2017 at 1:29 PM
    #627
    cynicalrider
    Jersey
    But at least at this pace you'll have a functioning front locker, unlike @jubei777 :stirthepot: :boink: Gonna keep ripping on ya till it's hooked up bud. :p
    jubei and Reh5108[QUOTED] like this.
  8. Apr 12, 2017 at 1:32 PM
    #628
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Aww yeea hahah I like this squad already! Im going out there to experience everything possible. an extra hour to a trailhead wont mean much compared to the drive Im in for anyhow :anonymous:.
    jubei likes this.
  9. Apr 12, 2017 at 1:33 PM
    #629
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You don't need a locker at all for the Kokopelli.
  10. Apr 12, 2017 at 1:34 PM
    #630
    Reh5108
    Idaho
    That's the spirit!
  11. Apr 12, 2017 at 2:10 PM
    #631
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    That's dope bro. Gonna be awesome to get some pep back. Mine is a hog with 33s :D
    Can't imagine 35s.
  12. Apr 12, 2017 at 2:41 PM
    #632
    cynicalrider
    Jersey
    Stop ruining our shit talking! :p you are more than welcome to join our newb caravan though Brett.
  13. Apr 12, 2017 at 2:48 PM
    #633
    Squeaky Penguin
    Brett
    Don't worry, I like making fun of Jason's slow progress as much as anybody.
    May be interested in hitting the kokopelli again, keep me updated.
  14. Apr 12, 2017 at 4:42 PM
    #634
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Solid pinion spacer too? Good timing, especially since they are throwing in free compressors.
    Reh5108 likes this.
  15. Apr 12, 2017 at 6:59 PM
    #635
    cynicalrider
    Jersey
    In the front diff? No, he said those with the Arb's shouldn't really need the spacer, I asked about it. I honestly don't know what the spacer does. :anonymous: any insight?
    jubei likes this.
  16. Apr 12, 2017 at 7:09 PM
    #636
    Reh5108
    Idaho
    From my understanding it is what keeps the backlash. Oem uses a crush sleave so if you ever need to remove the nut you have a good chance of changing your backlash. I could be wrong
    ToyRyd04 likes this.
  17. Apr 12, 2017 at 8:04 PM
    #637
    Squeaky Penguin
    Brett
    Sounds like you're talking about the ECGS bushing. ARB replaces the inferior OEM design.
    You would still probably want solid pinion spacers. ARB has no effect on that.
    alee891 likes this.
  18. Apr 13, 2017 at 5:49 AM
    #638
    jubei
    NoCo
    Stuff. Also things.
    It's all good, man! If shame and mockery help me get this damn thing done for RT, then I'll take it.
    I wouldn't expect any less of you assholes! Bring it on!
    :luvya:
    :D
    This is my understanding as well. The ARB replaces the needle bearing that causes so many problems on these trucks. In fact, you can see the new bushing in the clamshell on the side that accepts the stub shaft, I believe.
    Definitely a nice bonus after shelling out the money for the locker.
  19. Apr 13, 2017 at 5:55 AM
    #639
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    The crush sleeve is a single time use. There is also a tendency to hit the pinion flange on a rock and forcibly crush the sleeve past what the original gear set pinion preload was set at causing premature wear on bearings etc.
    Now that's worst case scenario......and it's less of a problem with the ifs diff because it's usually covered by skids and tucked up.
    What it does help with is that, if you have a pinion seal go bad or fubar a pinion flange, then when replacing you have the possibility of crushing the sleeve further on reinstall when torquing everything back to spec.
    jubei likes this.
  20. Apr 13, 2017 at 6:23 AM
    #640
    cynicalrider
    Jersey
    Thanks guys, I'll call ECGS today. :thumbsup: I figure considering the shit water I drive through all the time, a bad pinion seal is a possible issue one day.
