D Ring install on fender wells??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Clzay, Dec 2, 2011.
  1. Dec 2, 2011 at 5:24 PM
    Clzay
    Clzay [OP] Well-Known Member
    Clay
    Modesto, CA
    Cali Lean n mean... ha
    Hello, I haul two dirt bikes weekly an am having isssues with where my D Rings are located. Right now I have them in the front drain holes, but I need them wider and a little more spread out. I have a DC shortbed, So I was wondering if i could mount them to the top fender wells on the flat surface that backs up the the cab? If i use a backing plate will this be strong enough?
  2. Dec 2, 2011 at 5:29 PM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
  3. Dec 2, 2011 at 6:18 PM
    Clzay
    Clay
    Modesto, CA
    Not really what i need, nice idea thouigh. I like my D Rings an just want to mount them higher an wider so it'll support two bikes better. I just want to make sure i can mount them on the fender well?
  4. Dec 2, 2011 at 6:21 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Alright, well I'm sure if you put in a backing plate that would be fine. I would think that without the backing plate the d-ring would be too weak and over time would loosen and possible pull out of the holes due to stress over time.
  5. Dec 2, 2011 at 6:44 PM
    Clzay
    Clay
    Modesto, CA
    Yes! Now I really like that idea, as long as they are strong enough for two full size bikes while driving on bumpy fire roads... Do they flex or pull on the bed sides when bikes are tied down??
  6. Dec 2, 2011 at 6:50 PM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    OP, since pics are down i'll explain mine. Super easy, pulled front 2 bed bolts up slid the long end of pull style tie down (not rachet type) hook thru and rebolted bed bolt. when not being used i hook them to rear d rings and snug up so they dont bang around. I hook up street bike every weekend took 6 minutes
  7. Dec 2, 2011 at 9:09 PM
    tamer
    tamer hamerworx.com
    SoCal
    2009 SR5, 4x4, V6, 6-Speed AC, MGM
    I had no problem loading two sport bikes in the back of mine with the standard D rings.
  8. Dec 2, 2011 at 9:14 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I'm confused, (don't take much) the tops of the wheel wells are no wider than the two bed bolts (where most add extra d-rings), maybe a couple inches at most. Again maybe I don't understand.
  9. Dec 2, 2011 at 9:31 PM
    Clzay
    Clay
    Modesto, CA
    i few inches makes a big difference, it hard to explain in words. But when you have two bikes in the bed you have to spread the bikes apart far as possible to the bars dont rub. When you do this one of the D Rings is almost under the front tire of the dirt bike wanting to pull the tie down straight down, while the other tie down is pulling clear across the bed at an angle. So one tie down is super tight and the other is lose as a goose causing the bikes to be unstable on turns or bumpy roads. So I just wanted to mount some hooks or D Rings toward the outter most part of the bed. You ever seen the full size beds like on a Cheve, they have cut outs on the top rail of the bed and they work flawless for tying bikes down ;)
  10. Dec 2, 2011 at 9:56 PM
    t4daddy
    North Alabama
    I haul two motards in mine pretty regular. I've added extra d-rings under the bed bolts. Maybe the smaller 17inch rims help vs 21inch dirt rims. Have you tried hooking the bikes together in the middle, across the bars, then with one strap on the opposite sides, a total of three straps?
  11. Dec 2, 2011 at 10:07 PM
    Clzay
    Clay
    Modesto, CA
    Some of the guys i ride with are super picky about getting there levers scratched up, anyways... I just placed an ordered the Hook-ups tie downs so see if those do any better with two bikes on the back roads
  12. Dec 2, 2011 at 10:08 PM
    Clzay
    Clay
    Modesto, CA
    Oh an I have the Moto-gate as well
