D-RING INSTALL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sriracha Tacoma, May 19, 2017.
  1. May 19, 2017 at 10:01 AM
    Sriracha Tacoma
    Sriracha Tacoma [OP] t40fpv
    Hong
    2007 Silver Tacoma 4X4 TRD Access Cab
    3 inch Lift, All Terrain Tires and Rims
    Ok everyone, I attempted to install some D-Rings in the bed of my truck yesterday when I ended up stripped the inside of one of the screws since it was so tight.
    Now, I was wondering if anyone has any other ideas to drilling some holes to install them? Back and Middle is where I'm wanting to install them since I have two already at the tailgate.
    Thanks.
    ChadsPride likes this.
  2. May 19, 2017 at 10:09 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    People have drilled holes in the bed and mounted them in other locations. The only caveat is that they will not hold quite as well (they should still work just fine for most things), since the front bed bolts that are recommended for use in the DIY thread bolt directly to the frame. You also run the risk of additional rust any time you drill new holes in the bed, but that's easy to mitigate.
  3. May 19, 2017 at 10:11 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
  4. May 19, 2017 at 10:15 AM
    Gkim16
    Gkim16 Well-Known Member
    2016 White 4x4
  5. May 19, 2017 at 10:22 AM
    Sriracha Tacoma
    Hong
    Hmm...all good options, I thought about the Rust factor too and there is a spray to deal with that. But...I don't like drilling any new holes into the truck if I don't have. The ARB tie is good too, fyi, the tie downs aren't for anything serious. Just to hold my cooler, camping boxes in place while driving so nothing hardcore. lol
  6. May 19, 2017 at 10:31 AM
    YamaDirtrider
    Josh
    Elizabeth CO
    Those I listed have been in my bed for 2 ish years now and no rust. Been siting under water for a few days also. And still moves easly. They have a zinc coating os similar
    Another option is get a add in set that is similar to the swivel ones in the rear
