D-Rings and Bolts
Discussion in 'Towing' started by Performula, May 30, 2012.
  1. May 30, 2012 at 11:57 AM
    Performula
    Performula [OP] Six lugs of fury!
    Justinian the Gr3iht
    CO
    A no option 4WD vehicle.
    Alpine HU - Wow :)
    I cannot search on this iPhone. I hate to dedicate another thread but maybe more specific.
    Where can I buy D-Rings online and do I need to extend the Torx bolts at all?
    This is in reference to a 2010 Taco (I'm guessing 2005-2012 as well) and I'm talking about the ones in the bed, right behind the rear window. Thanks guys and gals.
  2. May 30, 2012 at 11:58 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Army surplus
    Ask them to ship using a USPS flat rate box to save on shipping.
  3. May 30, 2012 at 1:46 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    If you are looking for the Toyota factory D-rings specifically, any Toyota vendor such as toyotapartsales.com would carry them.
    The instructions for the Toyota D-rings have you drill a hole in your bed and attach with a metal backing plate behind the D-ring, thus the Torx bolt holding the bed does not need to be removed. I don't believe it requires a longer Torx bolt if you do so choose this route.
  4. May 30, 2012 at 1:48 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    2011 Dbl Cab TRD Sport
  5. May 30, 2012 at 1:54 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
