D rings front down mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wrseidel, Jul 28, 2010.
  1. Jul 28, 2010 at 6:54 PM
    wrseidel
    wrseidel [OP] New Member
    Bill
    Wisconsin
    2010 Base
    The 2010 Taco seriously lacks tie down capability in the bed of the truck. There are two light weights on the bed floor right and left near the tailgate and that is it. I want to add a few more. Any ideas on what to use, where to get them and where to mount them. I like the torqx bolts that hold the bed down and it looks pretty easy to spin them off and add some D rings but the rings need to have a single hole mount about 1/2" in diameter.
  2. Jul 28, 2010 at 6:57 PM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    Go up to the "Mods & Tutorials" button (look up and right on your screen)
    Hit "cheap tacoma mods"
    I think #2 in the 2nd gen section is how to add more D-rings
  3. Jul 28, 2010 at 6:58 PM
    bluescoops
    bluescoops Active Member
    06 4x4 sport Blue
    there is a thread about this in the cheap mod section
  4. Jul 28, 2010 at 7:20 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    I must be feeling kind this evening.
    I mounted two, along each side up by the cab. A 4" x 4" stainless backing. To me it makes a little more sense to have them up off the deck ..... and I didn't have to cut any holes in my mat.
  5. Jul 28, 2010 at 7:45 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
  6. Jul 28, 2010 at 7:47 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Welcome to TW!
  7. Jul 28, 2010 at 8:25 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    x2...you will need a t55 for the bed bolts. If you buy army surplus d rings that come 5 a pack drill the holes out with a 1/2" bit and then you will have to grind down one side of the washer on each bed bolt almost flush with the bolt head to have it sit flush on the d ring when you bolt it back on the bed.
  8. Jul 28, 2010 at 9:04 PM
    pinktaco808
    pinktaco808 Hot Steppa
  9. Jul 29, 2010 at 6:11 PM
    wrseidel
    Bill
    Wisconsin
    2010 Base
    Thanks all for the good advice. New to the Taco and really like the TW crowd so far. I did order some D rings made for the Humvee from Army surplus warehouse. May have to finesse them to make 'em work but we'll see. Thanks again.
  10. Jul 29, 2010 at 6:27 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I did the army surplus ones and I couldn't be happier. With the proper tools it was a 15 minute job.
  11. Jul 29, 2010 at 6:39 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    Virginia Beach
    2002 4x4 limited
    suspension and armor
    the ones you ordered fit the bed bolts perfect you just have to get the washer off the bed bolt. two easy ways. one is to take a dremel and grind down the ridges or i heard you can get a deep socket that fits over the head of the bolt and give it a good whack. they are strong and work great.
  12. Jul 29, 2010 at 6:53 PM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
  13. Jul 30, 2010 at 11:01 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I put the Toyota tie downs in about the same place. They are nice to have. I put scuba tanks up against the front of the bed standing up and a good tie down from d-ring to d-ring holds them in place nicely.
  14. Aug 18, 2010 at 6:14 PM
    Big Red 10
    Big Red 10 Member
    VA
    TRD Off Road
    I've read tons of stuff on these but I didn't see replacing those plastic ones in the bed rail with them. Is that easy? No extra hardware to get it into the track and work the same way?
  15. Aug 18, 2010 at 6:16 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Or just look at all the links at the bottom of this page...
  16. Aug 18, 2010 at 6:39 PM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    the socket trick only bent the big washer for me. I ground down the ridges on the bolt with my Dremel.
