D Shackle & Recovery Questions
Discussion in 'Recovery' started by Wolftaco0503, Nov 6, 2016.
  1. Nov 20, 2019 at 1:14 PM
    #61
    madcratebuilder
    madcratebuilder Well-Known Member
    PNW
    ZR2 Deepwood Green
    skidz, gears, tune, zeon 12-s
    It's based on the power of the motor and the strength of the gear box, then you use the appropriate rope/cable.
  2. Nov 22, 2019 at 11:13 AM
    #62
    BrianPVan
    BrianPVan Well-Known Member
    Brian
    BC
    2017 DCSB OffRoad
    Not having read the whole thread...
    Steel shackles and soft shackles are both necessary items in your recovery kit. There are times when one is beeter then the other. Me? I have 3 or 4 of each.
  3. Dec 3, 2019 at 4:16 PM
    #63
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    This.
    People who only carry soft shackles "because they're safer" likely don't have enough experience to understand they are only safer in some situations. In other situations they are almost certainly worse. This idea that synth is universally safer is just not correct.
    Since the advent of synth winch line, some people think that steel cables are all of a sudden less safe, however I would contend that's only true if you make a habit out of standing too close to your line while winching. As with anything, if you use it improperly, it's unsafe no matter what it's made of.
    BrianPVan[QUOTED] likes this.
  4. Dec 4, 2019 at 11:15 AM
    #64
    BrianPVan
    Brian
    BC
    2017 DCSB OffRoad
    True Dat!!
    Each has it's own advantages and disadvantages.
    jbrandt[QUOTED] likes this.
