D to E load range difference
Discussion in 'Wheels & Tires' started by kuntry09, Jul 16, 2011.
  1. Jul 16, 2011 at 8:11 AM
    kuntry09
    kuntry09 [OP] Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Will I be able to tell a major difference going from a load range D to a load range E? I'm wanting to get the kelly safari tsr but they only come in E for a 285/75/16 and I haven't found any other a/t that looks as aggressive. Thanks.
  2. Jul 16, 2011 at 8:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Run the appropriate psi and you should be fine.
  3. Jul 16, 2011 at 8:39 AM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    you'll be fine just like chris said lower the psi when you get them on the tire shop put 65psi in mine when they put em on .. too much for a small truck
  4. Jul 18, 2011 at 5:45 PM
    kuntry09
    Cam
    Douglas, Georgia
    Thanks that's what I was needing to know.
