DAC, anybody else almost sh@t themselves after using it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake1530, Sep 6, 2016.
  1. Sep 6, 2016 at 4:01 PM
    Jake1530
    Jake1530 [OP] Well-Known Member
    2015 Tacoma TRD
    I read the manual yes, I even have a few book marks in it, so I know it reads it'll make a noise when activating, but it sounded like transmission was going to fall out. Does anybody know how it works, is it the transmission down shifting or the brakes chattering?
  2. Sep 6, 2016 at 4:11 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    http://parts.olathetoyota.com/blog/7249/hac-dac-explained
    How DAC Works
    This system is for the other side of the hill you’ve just ascended. It works by noting the incline of the hill, presumably with the same sensors that work for the HAC. From here, the system keeps the speed of the car below 15mph. Working alongside the ABS and traction control built into the car, it constantly monitors and adjusts the amount of power and brakes applied to each wheel, allowing for the car to safely negotiate difficult terrain. It removes a lot of the driver error involved on going downhill.
  3. Sep 6, 2016 at 4:12 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    You mean the sound of steel cables about to snap?
    Yeah, I just got used to it. Only used it a few times going down steep hills. Kinda neat. Just ABS working.
    Jake1530[OP] likes this.
  4. Sep 6, 2016 at 4:15 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Just curious because I don't have it, but how is it different than just using 4lo in 1st gear? Does it move even slower?
    Sometimes even when going down really steep declines in 4lo/1st gear I have to give it gas because it's moving so slowly
    RJ_MacReady likes this.
  5. Sep 6, 2016 at 4:16 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Working alongside the ABS and traction control built into the truck, DAC monitors and adjusts the amount of power and brakes applied to each wheel. Your right... it sounds scary. :eek:
  6. Sep 6, 2016 at 4:19 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Didn't know tacomas had it
  7. Sep 6, 2016 at 4:30 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    15MPH? :eek::eek:o_O
    No wonder I couldn't get it to engage! I was on a rocky slope that you wouldn't want to go over 5mph on. I didn't and kept applying the brakes. Seriously, 15mph and you'd be bouncing off the road.:annoyed:
  8. Sep 6, 2016 at 4:32 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Actually, from the description, it does more than just keeping it below 15mph. It applies different braking forces to each wheel, depending on how the truck is behaving down the slope, to keep the truck in the most stable position.
    Going down a steep, slippery, rocky slope is very different than a smooth slope. If braking all 4 wheels, your truck can still slide or slip off the rocks, sending your truck sideways. DAC allows for certain wheels to spin to compensate.
    At least that's how I understand its function.
  9. Sep 6, 2016 at 5:00 PM
    Jake1530
    2015 Tacoma TRD
    Thank you folks, besides hearing other people's reaction to it makes me feel better I'm not alone, but more importantly thank you for explains how it works. I honestly thought the sound was coming from the transmission and I was somehow damaging it
  10. Sep 6, 2016 at 7:44 PM
    OffroadToy
    You have to take your foot off the brake pedal to engage DAC
    http://www.ttguide.net/downhill_assist_control_system-72.html
  11. Sep 6, 2016 at 10:10 PM
    BKinzey
    Beauford
    Hollywierd, CA
    You've misread my statement. I took my foot off the brake. When the truck began to exceed a safe speed for the conditions I reapplied the brakes. If the DAC truly lets your vehicle get to 15mph then it would be dangerous to rely on in a situation where 3 to 5mph would be a safe speed. I wasn't riding the brake and expecting the DAC to work.
    Looking at the link it states the DAC won't engage if you are travelling over 15mph.
  12. Sep 6, 2016 at 10:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    DAC is a nice thought for the autos, but just does not compare to manual 1st gear in 4low.
    eon_blue likes this.
  13. Sep 7, 2016 at 5:58 AM
    Sig45
    Mark
    Maine
    When I use DAC, my truck doesn't even get close to 15mph....I'd say it's closer to 5.
    This is steeper than it appears...was recently using it.
