Daily Drive Lift Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silvertaco17, Oct 27, 2015.
  1. Oct 27, 2015 at 8:57 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    She looks a little bit like the wife of one of my buddies. She's a stripper and works at a kind of expensive place.
  2. Oct 28, 2015 at 2:48 AM
    AKIRA 0NE
    AKIRA 0NE Instagram- FKN.AKIRA & ALOHA.DIVISION
    AKIRA
    Oahu, Hawaii
    '05 SSM DCSB pre-runner
    Debadged weathertechs mesh grill 6000K HIDs BHLM 2.5'' front 1.5'' rear stock snowflakes 2'' wheel spacers D ring hitch plasti-dipped interior pieces
    silvertaco17 IMHO you should get maxtrac spindles and an AAL like what's said above you could get that setup for around 1K without install it would ride the best and DCSBFTMFW is a buddy and knows his stuff :thumbsup:
  3. Nov 6, 2015 at 3:14 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Just did spindle lift with Dakars and block I got the CB drop kit the OME one what ells do I need
    got a small vibe
  4. Nov 6, 2015 at 3:19 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    :threadjacked:
    Do they make a spindle left less than 4"? I feel like 4" is pretty high to go for a daily driver, IMO.
  5. Nov 6, 2015 at 3:40 AM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    4" is it unless you feel like paying 2X the price to go down half an inch.
    And $1000 budget isn't even worth the trouble. I bought a fair share of used parts and my total for suspension and tires is $3000. That was with used tires that cost only $500. So that's $2500 just in lift and I still have to buy UCA's and new rear shocks among other things.
  6. Nov 6, 2015 at 3:49 AM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    OP, save your money up and do proper suspension work. If you go cheap, you actually wind up spending much more because you will end up doing it all over again.
    I've done a suspension cheap (wrong) on a Firebird. It was the worst riding car I have ever been in. I did a suspension right on my GTO..$1500 was just springs and shocks for that. In total my GTO has about 3k in the suspension. It rides low, it takes corners tight...and its still amazingly smooth.
    A budget of $1000 is basically no budget at all, especially for a 4 inch lift. My buddy did a 2 inch block lift with wheels and tires on his Silverado for $2200... and that was super cheap.
    My advice would be to do your research and price out the components you want/need. DO NOT base it solely on cost. Base it on what will be best for what you want in terms of use and feel. Price everything out, then save up to do it right.
    Sidenote...have you seen a Tacoma with 4 inches of lift? Thats a big lift. If this is your DD I think it would get cumbersome.
  7. Nov 6, 2015 at 3:51 AM
    TacoTaco15
    Jake
    VA
    Cumbersome = annoying as shit. That'd get old quick.
  8. Nov 6, 2015 at 8:02 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Ill second this. My previous DD truck had a 6" lift, and after a while it was annoying as shit. I will not lift my 15' Taco more than just to level it out with like a 2" spacer of sort. I dont plan on wheeling it through rocks and what not so the factory height is probably good enough for me to tool around some offroad areas for camping...
  9. Nov 6, 2015 at 10:28 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    (If you have a 2WD Pre-Runner)
    $320 - 4" lift spindles
    $85 - rear add-a-leaf spring
    $160 - Bilstein 5125
    $50 - rear lift block (optional)
    (use stock front shocks and coils/leafs)
    ~$610 for lift parts
    Estimate $300-500 for shop to install/alignment. Depends on the shop and labor rates. Or DIY and save $$$.
    End Result: 4" front lift..... 2"+ rear lift. No need for UCAs.
    If you feel that the 4" lift makes getting in/out of your truck a chore, then with the $$$ saved from above, purchase:
    $330 - 2" NFab Nerf Steps
    DIY install or est. $100 for a shop to do it.
    (Hope you have a wheel/tire solution to fill out the wheel well/fender space)
    OP requested:
    - 4 inch lift kit (CHECK)
    - for daily driver (CHECK)
    - don't need anything serious (CHECK)
    - function well on-road (CHECK)
    - simply for looks. (CHECK)
    - not looking to spend a ton of $$$ (CHECK)
  10. Nov 7, 2015 at 10:35 PM
    Pre runner2011
    Pre runner2011 Jekyll 2 Hyde
    Tucson Arizona
    2011 DCLB Prerunner
    K&N air filter, Banks Monster exhaust, steel screen grille, off road led lights, 3" Pro Comp suspension lift kit, 33x12.50-17 mud hogs, 17x9 Pro comp Stryker Wheels
    Pro Comp makes a 3" lift able to tuck 33's under it for $500.
  11. Nov 11, 2015 at 4:48 PM
    zboy
    Oahu808
    12 TRD OR
    I think its more like 3 -3 1/2 after all is settled down had to add some more lift W/COs too level out Rear Dakars W/aal & 1 1/2 Block
  12. Nov 11, 2015 at 5:09 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Why would a DD need a 4 inch lift? Put the money in a 401k, 50 years from now you will thank me.
  13. Nov 11, 2015 at 5:33 PM
    Tony V
    Tony V Well-Known Member
    Tony V
    south Texas
    2015 Trd Off Road
    I have a Rough Country 4" lift kit for sale for $800 still new in boxes. Was going to install but going LT. You pay shipping.
