Daily driver shocks upgrade?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MegaTacomaBro, Apr 19, 2020.
  1. Apr 19, 2020 at 5:47 PM
    MegaTacomaBro
    MegaTacomaBro [OP] Member
    bill
    2019 tacoma offroad double cab
    none yet
    I got a 2019 TRD Tacoma off-road with Bilstein 4600s on it but some bumps in the road make the truck almost dance across the road it feels like. I’m looking at a 5100 Bilstein upgrade but wasn’t sure if that would improve handling and the bumps?
    I’m doing mostly driving on the road and will on weekends go off roading but nothing extreme. Would 5100s fix my problem??
    bigmw likes this.
  2. Apr 19, 2020 at 5:49 PM
    bigmw
    bigmw Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
    Welcome to TW Bro!
    I would say you need a TRD Sport - like set up, not an off-road.
    Edit: nobody ever talks about Sport shocks on here, I don't even know what brand/ model is on there myself
    whatstcp and Blackbeard83 like this.
  3. Apr 19, 2020 at 5:50 PM
    MegaTacomaBro
    bill
    none yet
    Any recommendations?
    bigmw[QUOTED] likes this.
  4. Apr 19, 2020 at 5:52 PM
    bigmw
    Swap with a sport guy who wants a more off road setup. Should be easier to find than the other way around
  5. Apr 19, 2020 at 5:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Some people will argue that OR models aren't equipped with 4600s, but rather a smaller yellow bilstien set.
    4600's are similar to 5100's in performance but they lack adjustability. If you truly have 4600s you won't gain much from 5100's.
    But if you have stock OR shocks, 5100 will make a difference.
    71tattooguy, whatstcp and uwhusky12 like this.
  6. Apr 19, 2020 at 5:57 PM
    MegaTacomaBro
    bill
    none yet
    I have blue and yellow shocks I’ll look if I can see a number on them
  7. Apr 19, 2020 at 5:59 PM
    MegaTacomaBro
    bill
    none yet
    It just says Toyota Bilstein on them
  8. Apr 19, 2020 at 5:59 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    You probably don't like Bilstein in general then. Bilstein is digressive, meaning they are firm at a slower speed and gradually get softer the faster you go. The sports also have Bilstein in it, just has softer valving, but not much.
    I upgraded from my stock shocks to basically a 6112/5160 (a bit more expensive than 5100) and while it is a bit better, I still don't like it since I am used to Ranger Rovers and Cadilac suspension style. To get that type of feeling from suspension, you may need to swap out to Fox, Kings, ADS, or Radflo. I actually am in the process of swapping out my suspension again to Radflo and having them custom tune it specifically to my modded truck w/ compression adj so I can change it from cushy to firm when I go offroad.
    DTOM TACO and AKGSD like this.
  9. Apr 19, 2020 at 6:01 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    welcome Tbro , lots of choices
    MegaTacomaBro[OP] likes this.
  10. Apr 19, 2020 at 6:03 PM
    MegaTacomaBro
    bill
    none yet
    I did drive a lariat ford ranger a week ago and it’s suspension was like butter and it was the off-road model. So to get something like that I would need fox shocks or something like that?
  11. Apr 19, 2020 at 6:04 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    What’s your budget?
  12. Apr 19, 2020 at 6:06 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Get an Eibach Pro kit. Fairly inexpensive and pretty much what you need.
  13. Apr 19, 2020 at 6:07 PM
    ZekeR7
    Yes. Have you driven the TRD Pro yet? Those come stock with Foxes which is why it feels smoother and not as harsh when going over bumps. It's just preference at that point though. Some people like the firmness of Bilstein/Icon's digressive valving. Firm is better at taking corners, but you will feel every little bump on the road it seems like. Maybe you can find a used Pro suspension if your budget is tight. If not (atleast have $3k to spend) get yourself a fox, king, ADS, or Radflo w/ compression adj so you can do even smaller adjustments to your liking and will be the best suspension setup you can get.
  14. Apr 19, 2020 at 6:13 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    My sport came with Hitachi blue shocks.
  15. Apr 19, 2020 at 6:16 PM
    MegaTacomaBro
    bill
    none yet
    Yea I mean I like firmness but not that firm like... the back end Of the truck almost hops when I hit a series of bumps in the road. Feels like I’d lose control of it did that to much ya know? I’d be willing to save up for fox shocks absolutely if it won’t sacrifice off-road capacity
  16. Apr 19, 2020 at 6:24 PM
    ZekeR7
    None of the brands I mentioned including Bilstein will decrease the off-road capacity. It'll actually be better.
    I hear ya, you can put weight on the back in the meantime. It helped me out a bit having about 150lbs of weight to kinda keep it planted. Or you can change leaf pack to Dobsinson leaf pack if it's the rear that you only having an issue with so it MAY solve the problem, but that leaf pack is not meant for towing from what I am told so you do lose some of that capacity. $3k would be plenty to change leaf pack and get a better suspension. You don't have to get resi or compression adj if you are not offroading or going on fire roads a lot and may be able to drop the price down to $1.5k-$2k for a good set of fox.
  17. Apr 19, 2020 at 6:52 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Sport comes with hitachi, same as SR, SR5, and limited.
    Bill, the 5100s sound perfect for what you need. You will notice a huge difference immediately. If you ever load the truck bed up, look in to the 5160s for the rear, they are a step up in price but they feel amazing on and off road.
    wolf2600 likes this.
  18. Apr 19, 2020 at 6:55 PM
    jmauvais
    NorCal
    ...stuff
    how would Fox Shocks sacrifice off-road capacity? Fox would be a huge upgrade over the stock suspension and the 5100s, but typically the 5100s are used to provide a little lift and better ride for a budget friendly price. The fox suspension (like king, icon, ads) are all huge upgrades that are much better, but you pay a higher price for them.
  19. Apr 19, 2020 at 6:58 PM
    emmett
    emmett Well-Known Member
    Emmett
    06 Red TRD offroad 6spd
    Where are you located? I might trade you my sport shocks for the offroads...
    AKGSD and bigmw like this.
  20. Apr 19, 2020 at 7:02 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Not quite, the sport shocks are Hitachi, but they're different than the SR, SR5, and limited, those are softer. Sport shocks are tuned for on road performance and are firmer than the other trims.
    Speedfreak and danielgonzzz like this.
